Headlight/Nose support header
Old Mar 9, 2006 | 02:26 PM
evalu8r's Avatar
evalu8r
Default Headlight/Nose support header
I re-bonded this header in today, it seemed to take a lot of clamps and pressure to get this in and it seems to me that is why none of these seem to stay bonded. So my question is that would riveting be a better more perminent way to do this? Obviously it would require drilling and counter sinking the heads, but I still have to do body work so holes don't matter.
Chris
Old Mar 9, 2006 | 02:55 PM
big_G's Avatar
big_G
The bonding method is good and strong. What happens is the header rusts and the adhesive had nothing to hold to. Rivets will have nothing to hold to if you counter-sink them. The f'glass is too thin.
Old Mar 9, 2006 | 04:06 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
St. Louis used only bonding compound on about a half million C3s. You should be okay.
Old Mar 9, 2006 | 04:12 PM
Twin_Turbo's Avatar
Twin_Turbo
I used epoxy to bond mine, it's solid as a brick.
Old Mar 9, 2006 | 09:01 PM
evalu8r's Avatar
evalu8r
I used SEM epoxy and it is like a rock, I was just thinking. I went back and looked at the glass area and it is pretty thin there. Oh well I think I'm good then. So item # 963 is complete, starting to see light at the end of the tunnel.
Chris
Old Mar 10, 2006 | 08:51 AM
Vette Gator's Avatar
Vette Gator
Earlier model C3's were both riveted and bonded on. The problem is that over time, the rivet heads start to show as slight bulges in the paint. I believe that this is why Chevy went to the bonding only method later.
Old Mar 10, 2006 | 09:30 AM
Dalannex's Avatar
Dalannex
The bonding technique will work just fine for you. As long as you have the metal and the glass ground clean it'll stick just fine. Carry on to the next project.
-Justin
Old Mar 11, 2006 | 09:07 AM
seventysixvette's Avatar
seventysixvette
I just bonded a new header bar in also. I used SEM non sag SMC structural adhesive. They wanted 42 bucks for the 'special' gun this requires, so I modified my caulking gun and used it. I got my header bar from Corvette America. The first time I test-fit it it required a lot of pressure to push into full contact with the fiberglass. I tweaked the header bar untill I kinda had a happy medium between the glass shape and header bar shape. It didn't take much. You just never know if the fiberglass shape is perfect and you should tweak the bar to match it, or if you should be drawing the glass that 3/16" down to match the shape of the bar. Wot ever, It's a done deal now. Using the headlight frames to locate the bar worked great! Something I learned here! Being a supporting member of this forum paid off with that one hint!
John
To Headlight/Nose support header
