ZZ4 Engine Swap
Old Aug 13, 2001 | 10:45 PM
C3Vettesrock's Avatar
C3Vettesrock
Default ZZ4 Engine Swap
How much money would it cost to buy a zz4 engine and swap it out in a 77 corvette?
Old Aug 13, 2001 | 10:51 PM
78Vette-SA's Avatar
78Vette-SA
Default Re: ZZ4 Engine Swap (C3Vettesrock)
I'm sure some could give you more specifics, but I would guess with over 3k for the engine, then figure a couple hundred for the miscellaneous (pulleys, belts, brackets, whatever), and maybe a good radiator and/or electric fan while you were at it, and you're in around the 4k+ mark.
Sure would be a sweet ride though: :cool:
Old Aug 13, 2001 | 11:09 PM
C3Vettesrock
What about labor?
Old Aug 13, 2001 | 11:21 PM
Mike69@ECS's Avatar
0Mike69@ECS
Former Vendor
Cruise-In III Veteran
Cruise-In V Veteran
It's a prety straight forward swap. Figure around 3k for the motor. Add an additional 500-700 bucks for misc parts including waterpump, gaskets, headers and anything else you might need. As far as labor goes figure on about a full day of labor at whatever rate your mechanic charges. pulling the old motor dosent really take all that long, and dropping in the new really dosent take all that much time, but fine tuning it and being sure everything is hooked up proper takes time. I believe a properly set up shop could do it in 8-10 hours - provided they have all the parts you'll need and no real distractions to slow them down.
I hope that helps!
Old Aug 14, 2001 | 03:16 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: ZZ4 Engine Swap (Mike69)
Jegs has the motor for $3400 dollars with $200 delivery (to the Phoenix area, don't know about other areas).
I am also replacing the carb, starter, and the water pump as the same time. You can not use the water pump that comes with the ZZ4 as it is a "long" pump and the Vette requires a "short" pump with a 3/4 inch shaft.
I am budgeting $4200 - $4500 for the motor, the parts, and incedentals for the swap (oil, antifreeze, tools, BEER) and I am doing the swap my self.
Start time in 1 1/2 months !!! :D :D :D :D
Old Aug 14, 2001 | 08:43 AM
Mack's Avatar
Mack
Default Re: ZZ4 Engine Swap (BSeery)
Here's what it costs, if you do one of those, "While we're doing this..." installations. You'll notice that there are a lot of things you don't have to do, like the clutch, headers, starter, etc. You can subtract out what you don't want to do and get a good handle on costs. The cost for the engine was about as good as I could get at the time. The other costs are high.
The only thing I was sorry about was that I didn't look real close at the radiator. It was obviously damaged when I recently replaced it and it would have been a lot easier if I'd done it with the engine out of the car.
January 6, 1998 REPLACE ENGINE w/ ZZ4 - 89,582
2. Engine - GM ZZ4 HO $3,095.00
3. Rochester Q-Jet $486.55
4. Flywheel $282.00
5. Center Force Dual Friction Clutch $330.00
6. Hooker Super Comp Headers (Jet Hot) $488.95
7. Hurst shift Kit $199.50
8. Battery (78 Amp - 6 Year) $83.97
9. Fan Clutch $134.65
10. Adapter Assembly $16.50
11. Plug Wire Kit $92.14
12. Fuel Pump Assembly $35.70
13. High Torque Starter $220.71
14. Short Nosed Water Pump $144.64
15. Studs (4) $23.80
16. Paint for Frame & Engine Compartment $22.50
17. Gasket $0.94
18. Fitting $5.94
19. Spring $1.75
20. Clutch Boot $9.15
21. Gasket $6.60
22. Gasket Kit $13.53
23. Motor Mounts $95.50
24. Pulley $41.67
25. Hose $22.28
26. Clutch Fork $33.25
27. Fan Blade Assembly $78.29
28. PCV Valve $3.38
29. Spark plug Loom $6.94
30. Spark plug Loom $8.07
31. Stud $9.20
32. Seal $7.60
33. Seal (2) $3.64
34. Pin $1.20
35. Throw Out Bearing $34.99
36. Clutch Boot $22.05
37. Installation Kit $120.95
39. Sens Cool $26.17
40. Oil Filter $4.00
41. V Seal (2) $13.00
42. U-Joint $18.57
43. P/S Kit $22.20
44. Pilot Bushing $3.46
45. Seal (2) $13.38
46. Seal $9.10
47. A-Arm Bushing set $79.90
48. Clutch Rod $11.40
49. Valve $25.64
50. 5/8" Dia. Hose (8 Feet) $6.00
51. #10 Clamps (6) $2.82
52. Belt #7365 $11.81
53. Belt #7535 $14.85
54. Belt #7570 $16.22
55. Hose Fitting $7.95
56. Hose Fitting $7.50
57. Header Bolt Set $10.20
58. Coolant $15.90
59. 3/8 Dia. X 3 1/2" Bolt $3.21
60. Lower Radiator Hose $24.33
61. Cleaner $51.06
62. Modify Header Collectors $45.00
63. Freight $68.47
64. Tax $543.18
February 10, 1999 TOTAL $7,238.85
[Modified by Mack76, 6:45 AM 8/14/2001]
[Modified by Mack76, 6:46 AM 8/14/2001]
Old Aug 14, 2001 | 07:29 PM
1980ZZ4's Avatar
1980ZZ4
Default Re: ZZ4 Engine Swap (Mack76)
I just completed the installation of mine and am now working on the brakes. Here is a listing of my work:
ZZ4 $2900
Edelbrock Water Pump $150
Hooker Super Comps $490
Aluminized Exhaust w/stainless Magnaflows $650
Accel 10.5 Wires $100
New Power Steering Components $340
Rebuild Tranny and New Torque Conv. $625
New U-Joints $30
Holley 750 DP $340
Holley Fuel Pump $60
New Radiator $240
New Fan Shroud $125
Radiator Hoses $30
Fluids and Misc. Hardware $200 approx.
Aproximate Total $6300
Lucky we can do these projects over time! FYI, I'm totally happy with the results. The engine performs better than expected!!! :D :cool: :cool: :cool:
Old Aug 14, 2001 | 10:06 PM
BSeery's Avatar
BSeery
CI 6-7-8 Veteran
Default Re: ZZ4 Engine Swap (1980ZZ4)
where did you get the motor for $2900 :eek: :eek: :eek:
Old Aug 14, 2001 | 11:13 PM
my74ls4's Avatar
my74ls4
I just installed a crate motor from scoggins-dickey for $3100.00 in my other toy a 81 Z28. It's not a ZZ4 but the block has the ZZ4 rotating assembly , vortec heads , edelbrock performer rpm intake , GM LT4 HOT CAM , all roller motor. The motor dyno'd at 407hp and 410 ft/lbs of torque. For the price you can't beat the horse power. Would recomend this setup to anyone. My 3850 lbs of car and me ran a 13.66 at 100 mph on street tires. They don't really advertise this to much I guess it would hurt their ZZ4 sales!
Old Aug 15, 2001 | 01:17 AM
Cruzmeisters's Avatar
Cruzmeisters
Default Re: ZZ4 Engine Swap (my74ls4)
I was planning on buying a ZZ4 "sometime"...and procrastinating. One August a.m. in '99 I saw an ad in the Pgh. Post Gazette: "NEW ZZ4 in crate, private party, $2500". I called the guy, he had some projects that he wanted to finish, needed cash. He bought it from "Unis Chevrolet", Aliquippa, Pa. for $2900 through his buddy, who was the Service Mgr. He delivered it to my bud's garage in Edgewood for $50. I'm an old "coupon clipper" and couldn't pass up a bargain. Also, it pushed me into finally getting my BUTT "in gear" and doing the swap...and I've never been happier! :D
Cruz
Old Aug 15, 2001 | 01:08 PM
71 4 me's Avatar
71 4 me
Hi Everyone:
What flywheel and clutch did everyone use for the ZZ4?
Thanks,
Brian
Old Aug 15, 2001 | 03:42 PM
1980ZZ4's Avatar
1980ZZ4
Default Re: ZZ4 Engine Swap (71 4 me)
I got mine from a neighbor who owns an auto repair shop. Use your network, if you know someone who owns a shop, they might be able to save you a few bucks. The engine comes with a flywheel already. No clutch, I have a T350. Good Luck :cool: :cool:
Old Aug 15, 2001 | 03:52 PM
Mack's Avatar
Mack
I used a 12 3/4" GM flywheel... Weighs about 15#... P/N 14088646.
Centerforce Dual Friction clutch.
To ZZ4 Engine Swap
