Brighter headlights
Old Mar 12, 2006 | 10:21 PM
Batsy74's Avatar
Batsy74
Originally Posted by markdtn
There was a post a year or so ago about changing to aircraft landing lights.
Landing Lights
Old Mar 12, 2006 | 10:37 PM
MN-Brent's Avatar
MN-Brent
Originally Posted by norvalwilhelm
2 30 amp Bosch relays and 2 fuse holders is all you need. Those relays are about $5.00 each. With the relays the dimmer switch and the head light switch should last forever.
It really makes a difference in the brightness with the stock headlights.
Thanks Norval
What would be the original intended usage for this 30Amp relay? Fuel pump relays or injection system or ?
Brent.....
Old Mar 13, 2006 | 12:38 AM
Bee Jay's Avatar
Bee Jay
Our problem is lack of proper voltage to the head lights. We are often down around 12 volts or even less by the time the alternator travels to the fuse block through the switch and back out to the lights.
I really noticed a difference with installing relays right by the lights and feeding a dedicated line directly from the alternater
I agree also. I have four relays, one for low beam, one for high beam, one for the always on now front driving lights, and one for my fans. I also switched to H1/H4 with 100w bulbs in high. Lights up the night.
Bee Jay
Old Mar 13, 2006 | 09:31 AM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
well sort of... Even though what you say is true enough, with the new halogen bulbs available off the shelf, this really makes installing the relay unneccesary. And yes I have done it both ways. Try the new bulbs first, then if you are still not satified than try the relay method.
Remember
Easy solution first !!!!!
tim
Old Mar 13, 2006 | 11:59 AM
norvalwilhelm's Avatar
norvalwilhelm
Remember
tim
One of my big things with the relays is the headlight switch no longer carries the load, nor does the dimmer switch.
Another plus is the interior of the car was only so much power. By using your method all this power is taken from the fuse block, with the relays it comes directly from the alternator so the interior never sees this large power drop.
If you monitored interior voltage you would see a drop when you turned the lights on and while idleing in traffic you would really see it in the 12 of lower volt range.
By having the external relays and watching the volt meter you barely see it flicker when the lights are turned on. This is not the case using the normal light switch.
I also dread ever having the change that switch.
The bosch relays are only general purpose and all allll switching should be done with relays, fans, pumps, lights, everything. Switches are only used to activate relays.
Look at new cars??? NOthing but relays
Old Mar 13, 2006 | 12:10 PM
sweethence's Avatar
sweethence
Quite right quite right, in fact i watch em brighten when revving the engine
But in my case, i blew a light and replaced it with holgen while driving at night one day. the difference between the old and the new was so huge, i drove right back to autozone and replaced the other three, saw no ned to do the relay upgrade (like i did for my 67 camaro). I agree 100 percent about the relay improving the performance ( higher and steadyier voltage) of the lights as well as reducing load on the wiring in the car, but as far as just seeing better what a difference. as far as the wiring goes, well if you have issues there, it best to just replace the entire harness on a 30plus year old care as a rule of thumb
.02
tim
