Brighter headlights
Old Mar 11, 2006 | 08:22 AM
drswitala's Avatar
drswitala
Default Brighter headlights
What can I do to improve the brightness of my stock 80 headlights. They are now like driving with two birthday cake candles on the front of the car to light the road.
Old Mar 11, 2006 | 08:39 AM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
put halogens in and make sure their adjusted properly...
Old Mar 11, 2006 | 08:46 AM
drswitala's Avatar
drswitala
Can I get these at a local parts store (Advance Auto, Murrays)?
Old Mar 11, 2006 | 09:19 AM
shafrs3's Avatar
shafrs3
First off, change your bulbs with some fresh ones. Over time the bulbs loose focus due to lens pitting from road sand. If you've ever noticed, a windshield over time accumulates small pits from dirt being kicked up from the road. Also, the light the filament emits yellows over time, I don't remember the actual process that causes this, but if you've ever bought a new car, or noticed the oncoming lights from a new car, the light being emitted is a whiter light. I'm comparing halogen to halogen here, not the new xenon lights with halogens.
Second, you should check the alternator voltage output and be sure it's generating voltage within specs. It should be about 14.5 VDC. If it is down even 1 volt, that will affect brightness noticeably.
From this point you can get more involved by rewiring the headlights to include relays that feed the lights with heavier gauge wire. This is a popular upgrade that ensures the full 14.5 volts is reaching the bulbs. Hope this helps.
Old Mar 11, 2006 | 10:08 AM
comp's Avatar
comp
yep
Old Mar 11, 2006 | 11:02 AM
norvalwilhelm's Avatar
norvalwilhelm
Originally Posted by comp
yep
Our problem is lack of proper voltage to the head lights. We are often down around 12 volts or even less by the time the alternator travels to the fuse block through the switch and back out to the lights.
I really noticed a difference with installing relays right by the lights and feeding a dedicated line directly from the alternater
Old Mar 11, 2006 | 11:20 AM
Twin_Turbo's Avatar
Twin_Turbo
Old Mar 11, 2006 | 12:50 PM
rcread's Avatar
rcread
Here's an article from MAD Electrical dealing with brighter headlights.
http://www.madelectrical.com/electri...adlights.shtml
Old Mar 11, 2006 | 12:59 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
My 77 had the original incandescents until about 4 years ago. The change to halogens at the same rated power was like night and day (literally). Once I find a set for a decent price, I'm going to Hella H1/H4 lights, probably with 100/55 H4 bulbs on the outside.
Old Mar 11, 2006 | 03:47 PM
Corvette Engineering's Avatar
0Corvette Engineering
Former Vendor
I've got hallogens in my '69 and on a dark night in the middle of Iowa, no moon, no traffic when I lit up the high beams it was like daytime. Nothing better than 4 Hallogens blazing away, but now you've got me thinking about relays.
Old Mar 11, 2006 | 03:54 PM
dgruenke's Avatar
dgruenke
Definitely go with halogens. This should make an immediate difference, even if you aren't getting the exact voltage that you should.
Old Mar 11, 2006 | 07:00 PM
68/70Vette's Avatar
68/70Vette
If your headlamps are really old, I think that metallization can occur as metal boils off the filament and deposits on the interior part of the lens. Nothing you can do about this except change the headlight bulbs. Another possibility is that with aging, the connectors become corroded and you start to get a little extra voltage drop through the connectors. Actually adding relays to power the headlights seems like a good idea (see the MAD electrical reference in previous posts). A question about Halogens. For early C3's, we need the T3 headlight bulbs since they accomodate the fiber optics. Will halogens allow the fiber optics to work?
Also, wasn't there a post not too long ago about someone who put aircraft lights in his car? He put one on the passenger's side since it was so bright it was not a good ideal to put it on the drivers side. I think it was a 150 watt lightbulb with a narrow beam. It did fit in the C3 headlight assembly.
Old Mar 11, 2006 | 07:06 PM
oregonsharkman's Avatar
oregonsharkman
Originally Posted by 68/70Vette
If your headlamps are really old, I think that metallization can occur as metal boils off the filament and deposits on the interior part of the lens. Nothing you can do about this except change the headlight bulbs. Another possibility is that with aging, the connectors become corroded and you start to get a little extra voltage drop through the connectors..
What are you??? Some sort of Engineer or something
Old Mar 11, 2006 | 07:49 PM
Older Than Dirt's Avatar
Older Than Dirt
It's a good idea to use relays especially with halogens, actually it's best to use them even if you're still using the stock headlamps. In the stock wiring configuration the headlight switch and dimmer switch contacts are taking the full load of the headlamp current. Powering the headlamps through relays with a new 12v source(s) will eliminate the load from the dimmer and light switch, they would only be triggering the coil in the relays. You headlights will work better and your headlight switch and dimmer will last probably forever. Basically it's the same as wiring for electric fans, the temperature sensor operates the relay coils. In this case the headlight switch and dimmer operates the relay coils.
Old Mar 12, 2006 | 08:27 AM
drswitala's Avatar
drswitala
Thanks to all. Got some really good advice here. I think I will go with the easy route first and install the hallogens. If this does not work to my satisfaction I will look into the relays and etc.
Old Mar 12, 2006 | 11:44 AM
1Z87L8's Avatar
1Z87L8
some manufacturer actually made a harness kit with the relays ready to go. it was plug and play for $49.95 if i remember right.
if i find the link in the million i have saved i will post it.
i did find this link though detailing how to wire the relay's
http://www.rowand.net/Shop/Tech/imag...ingDiagram.jpg
this diagram may be a little easier to understand
http://www.73-87.com/7387garage/exte...y81-87Quad.jpg
Old Mar 12, 2006 | 11:58 AM
jdmick's Avatar
jdmick
I picked up 4 Wagner halogen bulbs at a local parts store yesterday for about $30. Between being old, pitted, non-halogen, and sprayed with paint the old ones were downright dangerous.
To Brighter headlights
Old Mar 12, 2006 | 03:18 PM
MN-Brent's Avatar
MN-Brent
What type relays would be recommended?
Old Mar 12, 2006 | 04:39 PM
norvalwilhelm
2 30 amp Bosch relays and 2 fuse holders is all you need. Those relays are about $5.00 each. With the relays the dimmer switch and the head light switch should last forever.
It really makes a difference in the brightness with the stock headlights.
Old Mar 12, 2006 | 08:59 PM
markdtn's Avatar
markdtn
There was a post a year or so ago about changing to aircraft landing lights.
