battery ground
Old Mar 11, 2006 | 12:49 PM
troy1m's Avatar
troy1m
Default battery ground
can someone tell me where the neg. battery cable on my 76 bolts to the car gnd. system? i've lost my gnd.
Old Mar 11, 2006 | 01:02 PM
694speed350's Avatar
694speed350
on my 69 i's boltted to the rear crossmember under the battery box.
Old Mar 11, 2006 | 01:31 PM
troy1m's Avatar
troy1m
Default thanks
thanks 69 4 speed it's in the same place on the 76
Old Mar 11, 2006 | 05:09 PM
Steve COSD's Avatar
Steve COSD
To get a good ground on the C3s first clean the frame at the bolt area.
Then install in this order next to the frame. Star washer, Cable end, flat washer and then the bolt. The trick to a good ground is the star washer. Many novice mechanics will forget or will just leave this off.
Another area for proper ground is at the front of the car. There is a short ground cable that runs from the bottom of the frame side motor mount location to the top of the L-shape bracket that supports the starter motor. Make sure both of these connections have the star washer also.
Let us know how you fair.
Good Luck
Steve
To battery ground
