Please Help - Stuck Oil pan
Old Mar 11, 2006 | 04:00 PM
BB68Vett's Avatar
BB68Vett
Default Please Help - Stuck Oil pan
I am in the middle of changing my oil pan gasket. The oil pan bolts have been removed and I lowered the steering linkage. Problem is the oil pan is stuck to the block. I do not want to jam a screwdriver between the block and the pan and I have tried tapping the side of the pan with a rubber mallet. It simply won't budge. Any other ideas? Thanks.
Old Mar 11, 2006 | 04:30 PM
Desertvette's Avatar
Desertvette
Use a 2" putty knife ,with the blade sharpened to a knifes edge ,and a hammer to drive it around the perimeter of the pan.
LOL Bob
Old Mar 11, 2006 | 04:37 PM
Danspeed1's Avatar
Danspeed1
Putty knife is a good idea. Try getting a razor blade in there too, to cut away some of the silicone. In the end your best bet will probably be to get a screwdriver in there and pry it out. I wouldn't worry about the engine,... its cast iron and your not going to damage it. In the event the pan gets screwed up (which I haven't had happen yet) you can always straighten it out after its out of the car or just replace it if it bothers you that much.
Hope this helps,
Dan
Old Mar 11, 2006 | 04:50 PM
BB68Vett's Avatar
BB68Vett
OK. I'll try it. Thanks, guys.
Old Mar 11, 2006 | 05:31 PM
BB68Vett's Avatar
BB68Vett
Well, it worked. Once again, thanks for the tip guys.
To Please Help - Stuck Oil pan
