Master cylinder pushrod question.
Old Mar 12, 2006 | 11:28 AM
70 LS1's Avatar
70 LS1
Default Master cylinder pushrod question.
how deep is the hole in the back of a power master cylinder? Is the pushrod in the booster adjustable at all?
Old Mar 12, 2006 | 07:24 PM
69autoXr's Avatar
69autoXr
Approximately 1.6"
The pushrod is adjustable, but I don't know what the range of adjustment is off hand.
Old Mar 12, 2006 | 10:08 PM
70 LS1's Avatar
70 LS1
Is it the same as the manual masters for the early years?
How deep is the hole for the later years?
Old Mar 13, 2006 | 08:33 AM
69autoXr's Avatar
69autoXr
If not the same it is very close, I mistakenly had a manual master on my power system for about 7 years.
Not sure about the masters for later years, call VBP they can tell you.
Old Mar 13, 2006 | 08:52 PM
70 LS1's Avatar
70 LS1
Anyone else know the depth for later C3's? I am trying to see if the later boosters are compatible with my C5 master cylinder.
Old Mar 13, 2006 | 09:20 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
you can buy a new, not rebuild master for $50 or $75 bucks..why not go that route?
Old Mar 13, 2006 | 10:03 PM
70 LS1's Avatar
70 LS1
Because I already have a C5 master cylinder to go with my C5 rotors and calipers. The C5 master has a smaller bore (13/16") and builds more line pressure than a C3 master. This higher pressure is necessary for the smaller lighter C5 calipers to work properly.
I just want to know if I can use a C3 booster or if I should use the C5 booster and make it fit.
To Master cylinder pushrod question.
