Oil temperature sending unit?
Mar 12, 2006 | 08:02 PM
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Where's a good location for a oil temperature sender??
I was thinking in the oil pan drain plug, but that would be a pain. Where's a good location to install the temperature sensor?
Mar 12, 2006 | 08:06 PM
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
if you have the pan off, look in there to see where the pump pickup is and have a bung welded in for it on the other side of the pan from it.
Mar 12, 2006 | 08:12 PM
Quote:
I don't really wanna have anything weled on the pan... If I'll install the sensor on the pan, it would be at the drain plug...
Mar 12, 2006 | 08:47 PM
On the 82's it's in the other oil pressure port just above the filter I think.
Mar 12, 2006 | 08:53 PM
St. Jude Donor '09
better yet, ask your engine builder.
Mar 12, 2006 | 09:03 PM
Mar 12, 2006 | 09:14 PM
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Drilling a hole and welding the bung is the best way. Is pan powdercoated or something? It would take 5 minutes to do. Your engine guy can do it.
Some folks tap into a plug on an oil cooler adapter between block and filter.
JIM
Mar 12, 2006 | 09:17 PM
I am having a fitting welded to the pan.
Mar 12, 2006 | 09:18 PM
JIM
I'll see if they could do it.. Why can't I just use the drain plug hole?
Mar 12, 2006 | 09:24 PM
Quote:
Good place for a sending unit.
Mar 12, 2006 | 09:27 PM
I wonder if the block has a plug there... That would be nice..
Mar 12, 2006 | 09:39 PM
It does, but it may be a bugger to get out.
Mar 12, 2006 | 09:48 PM
Quote:
I can ask the shop to remove it and instll the temp. sensor..
Mar 12, 2006 | 10:58 PM
All passenger side dipstick blocks should have a bung next to the filter. Just ask your builder to tap it. It is no big deal.
