Argh! Broken Rear Spring Bolts
Actually I only snapped two. The other one was already snapped...which is why I was trying to remove the other two. For those of you turning wrenches on your cars...use anti-seize on the threads of a steel bolt turned into aluminum.
I do have access to a rear end out of an '81. Or I suppose I could take the original to a machine shop.
Any suggestions???
Been there buddy
...the deal with steel bolts on aluminum is always a head-ache without a type of anti-sieze compound...and has been for years.
When aluminum parts first started showing up consistantly on the American car market, (around the 80's) breaking soft steel bolts in aluminum was a very common problem...from under the hood, to other components, impact wrench or not.
Then came harder steel bolts on aluminum.
Hence the invention of the heli-coil (and for other reasons of course).
Use of heat was an option; but would also distort or ruin the aluminum if it was done wrong, and even that sometimes didnt help.
Anti-sieze was the only answer (unless a person routinely loosens and retightens their bolts and nuts)...and is still the only approach that corrects this, not to mention; anti-sieze does wonders for steel-on-steel applications.
It is, and will always be a PITA unless anti-sieze is used.
G/L
Jim
I've snapped thermostat housing bolts and then rear spring bolts. Any suggestions for more bolts I can snap?
The good news is I have an option. All three bolt ends are in the cover assembly so that's all I'd have to replace. I do have one readily available.
But I think the driver side yoke seal is leaking. And while I'm at it I might as well change the U-joints.
Anybody have any suggestions of who can change the seals (without costing an arm and a leg) in the Phoenix area, especially the East Valley?
When I purchased my 1980 one of the rear spring bolts was broken off. I took it to a machine shop where they removed the broken bolt and did a heli-coil thread replacement.
REMOVAL WILL BE A LOT EASIER FOR A MACHINE SHOP IF YOU DON'T TRY TO REMOVE THE BOLT WITH AN EASY OUT.
Pretty quick repair. They will most likely want you to drain the differential.
One of the reasons I'd like a professional change the seals is to have him check the guts.
That part of your post sounds familiar to a lot of us I'm sure
gets me in trouble every time $$$$$$$
ez outs will prob work with PB pen. oil...otherwise machine shop. If you ruin holes, convert to Heli-Coil or eqiv. good luck
