Engine had us saying WTF!
Old Mar 13, 2006 | 11:53 PM
Higs's Avatar
Higs
Default Engine had us saying WTF!
Here is the deal. 80 350CI, GM aluminum 58CC Heads 1.94/1.50 valves, Edelbrock Intake, Edelbrock Carb w/ vacume 2nds, Original block. That's all I can confirm at this time.
Knocking sound from engine. Pull #1 plug wire off dist and restart. Sounds and runs the same. Put back on and pull #2 wire off and restart. Sounds the same. Put #1 wire on #2 and #2 on #1, sounds the same.
How could this be? Could all the lobes be off the cam and the valves are not opening enough to make a difference? Next step is check compression but this is just plain weird. Thanks for listening.
Old Mar 14, 2006 | 12:10 AM
Fubba's Avatar
Fubba
58cc...that's a crapload of compression. What's your CR? What octane fuel are you running?
Old Mar 14, 2006 | 07:03 AM
Higs's Avatar
Higs
Has got to have domed pistons with these heads, but I don't know at this time. Runs on pump gas.
Old Mar 14, 2006 | 08:52 AM
bashcraft's Avatar
bashcraft
So you're saying that #1 and #2 aren't firing? Have you checked for spark? How about the plugs?
Old Mar 14, 2006 | 09:02 AM
jackson's Avatar
jackson
OE L98 vette aluminum heads are 58cc ... came new with dished pistons ... L98 heads a popular, reasonably-priced upgrade to other sbc. ZZ4 comes with same heads.
Old Mar 14, 2006 | 11:23 PM
Fubba's Avatar
Fubba
Okay...all I can think about is flat-tops flat-tops flat-tops for some reason. sorry
Old Mar 14, 2006 | 11:55 PM
Higs's Avatar
Higs
There was a kid with a Flat Top when I was growing up. I think his name was Fubba. Sorrry, I could not resist.
My son came out to the house tonight and listened to the problem black vette. Took it out for a test drive. Got out with a smile on his face. Opened a fresh brew. Lit up a smoke. Calmly said "Dude, you have a bad header gasket , dirty carb and this thing haules ***"!
I said well since your so smart, why is the Red one such a dog? He then proceeded to remove the air cleaner and said "Dude, get in the car and mash the gas to the floor". Then he opened a fresh brew, lit up a smoke and calmly said, "Dude, your gas pedal rod is bent and you're only running on two barrel's".
Damn, I hate smart *** kids that know everything! What would we do without them.
Old Mar 15, 2006 | 12:33 AM
kdf1986's Avatar
kdf1986
Dude....you got one very smart kid.
kdf
Old Mar 15, 2006 | 07:12 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
glad you found the problem
To Engine had us saying WTF!
