700R4 - 4L60E Tech Tool Question
Old Mar 15, 2006 | 08:03 AM
Tom454's Avatar
Tom454
Default 700R4 - 4L60E Tech Tool Question
Here is a list of the ATEC tools for the 700R4.... I am working on a 4L60E which requires different tools than the 4L60. Which ones in this list do I absolutely HAVE to buy to do the overhaul? I realize if the governor bore is shot I need the T-1017, but assume it's just a "average" overhaul... any experts on-board?
T-0030-A H gauge front pump clearance gauge 62.99
T-0107 Governor Bore Repair Tool 68.31
T-0107-D Governor Bore Bushing Driver (for 30104-A bushing) 27.24
T-0127 Accumulator Servo Piston Remover 166.21
T-0131 Extension Housing Seal Installer 21.41
T-0149 Input Clutch Housing Spring Compressor 27.65
T-0151 Rear Clutch Spring Compressor 29.28
T-0160-A Ext Housing Bushing Remover & Installer 108.69
T-0163-A Vacuum Pump 104.15
T-0220-700R4 Bushing Drivers 155.45
T-1001 Shift Lever Seal Remover/Installer 29.25
T-1264 Converter End Play Checker 246.47
T-1055 Oil Pump Remover & End Play Tool 57.54
T-1063 Pump Seal Installer 26.59
T-1068 Front Endplay Tool (for 245mm torque converter) 55.25
T-1071-A Direct Clutch Accumulator Piston Remover & Installer 46.15
T-1092 Bearing Race Installer 102.52
T-1097 Front Pump Alignment Band 27.72
T-1501 Speed Sensor Remover 134.32
T-1502 Speed Sensor Rotor Installer Kit 511.52
T-1503 Stator Shaft Teflon Seal Installer Resizer 110.27
T-1517 Air Test Plate 175.48
T-1527 Overrun Clutch Inner Lip Seal Installer Protector 16.21
T-1528 Forward Clutch Inner Lip Seal Installer Protector 15.33
T-1529 Park Neutral Switch Aligner 45.88
T-1560 Output Shaft Support Fixture 58.95
T-1561 Intermediate Band Apply Pin Gauge 295.51
T-1571 Sun Gear Puller 82.81
T-1574 Turbine Shaft Teflon Seal Installer (A&B) 74.87
T-1574-A Turbine Shaft Teflon Seal Installer (A) 63.52
T-1574-B Turbine Shaft Teflon Seal Resizer (B) 16.89
T-1574-C Turbine Shaft Teflon Seal Inst/Resiz (C) "cap" 2.76
T-1574-LONG Turbine Shaft Teflon Seal Installer 4L60E only need this one for 4L60E
T-1702 Pressure Regulator Valve Snap Ring Installer 38.28
T-1703 Front Pump Spring Loader Tool 47.37
T-1735 Servo Cover Depresser (use with pan on or off) 195.2
T-1891 Trans Oil Cooler Line Disconnect (1996 later trucks) 84.84
T-2009 Endplay Adapter 4L60E 117.72
T-2030 Input Shaft Teflon Seal Installer
T-3423 Extension Housing Seal Installer 122.82
30104-A Governor Bore Bushing (GM) 9.15
Old Mar 15, 2006 | 08:58 AM
mrvette's Avatar
mrvette
IF all you doing is a soft parts overhaul, none of them, but you have to get inventive with your thinking as to how to git her dun with your well equipt normal shop tools...I use 6" C clamps on my bench to do the clutch packs with, for instance,
GENE
Old Mar 15, 2006 | 09:18 AM
Tom454's Avatar
Tom454
GENE
How about the teflon seal installer/resizers? They claim the job is nearly impossible to do without the tool & avoid damaging the seals?
What about the pump alignment band? How do you center it without the tool?
Ditto the front pump remover & endplay tool... how do you do that job without the tool?
What do you use to remove/install the extension housing bushing?
I have tools/drivers for the C6, AOD, T350/400 bushing.... but none for the 4L60E.
Can you replace the bearing seats without their special driver (& not damage ther seats) ?
I already bought $5.00 worth of PVC fittings to install the front & rear seals, so I can skip those two drivers. Tried the front seal with a hammer & it didn't go too well... the housing is not perfectly round.... seal would not go in without damage.
I'll brave it without the tools if it can be done... so that's the deal? None of them?
To 700R4 - 4L60E Tech Tool Question
