Coolant Leak
Old Mar 15, 2006 | 08:46 PM
bmankin's Avatar
bmankin
Default Coolant Leak
Where would coolant be coming from if it was dripping off the starter?
Old Mar 15, 2006 | 08:50 PM
hoosiervette's Avatar
hoosiervette
St. Jude Donor '14-'15-'16
Could possibly be a bad freeze plug?
Old Mar 15, 2006 | 09:02 PM
icanfixitforyou's Avatar
icanfixitforyou
If you can not see the source it may be a freeze plug at the back of the engine block. The trans has to be dropped to get at it. Cost of freeze plug - negligible - a buck or two, cost of labor to drop trans and install said plug, well that is another story...
Good luck!
Old Mar 15, 2006 | 09:24 PM
markdtn's Avatar
markdtn
Also could be coming off the back of the intake. Could be coming between the head and block. You need to pressurize the system with it cold so you can find the leak.
Old Mar 15, 2006 | 09:31 PM
redwingvette's Avatar
redwingvette
Right above th starter is a plug in the head that may be where the leak is if your lucky.
Old Mar 15, 2006 | 10:47 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
That's exactly where I noticed my 78SA leaking from. Rear water passage at the intake manifold. Dripping from the starter and the hole at the bottom of the flywheel cover. New intake gaskets cured it.
Mike
Old Mar 16, 2006 | 08:00 AM
bmankin's Avatar
bmankin
I just started it for the 1st time. It was running good. Thanks for the info.
Old Mar 16, 2006 | 09:38 PM
bmankin's Avatar
bmankin
Y'all were right. It was a freeze plug. Machine Shop said they would come to the house and replace it. Engine was done about two years ago. How about that for service?
Old Mar 17, 2006 | 09:48 AM
gonzo14's Avatar
gonzo14
"Give that man a CEEEEGAR" (machine shop man I mean)
Old Mar 17, 2006 | 10:23 AM
73 red vette's Avatar
73 red vette
Now that's what I call "customer service".Put his name and number up on the site for people to see in case someone else in your area needs some work from a great shop like that.
Old Mar 17, 2006 | 01:42 PM
jackson's Avatar
jackson
Default ? rubber or metal freeze plug ?
Service sounds almost too good to be true! Are they gonna replace it with a metal one that's a drive-in fit like what's probably in there (correct but difficult to do in car) ... or ... with a rubber&steel type that tightens with a wrench (cheap & MUCH easier to do)?
Old Mar 17, 2006 | 11:58 PM
bmankin's Avatar
bmankin
Said he would only use a drive-in. Neal's Cylinder Heads in Murfreesboro, TN. Its a father and Son operation. They mainly stay busy on racing engines. They have only been here for a couple of years. I just stopped in when I started my project and really felt good about the place. He talked me out of a couple of things I thought were "necessary" that he could have easily profited off of.
Old Mar 18, 2006 | 09:13 AM
carl a's Avatar
carl a
if it coming from the area of the starter i would check the hose clamps on the heater hoses going right there to the heater core,,give them a 1/4 turn with a ratchet
Old Mar 18, 2006 | 08:27 PM
bmankin's Avatar
bmankin
It was the Freeze Plug for sure. Right out of the middle of it. What's the chances of that? Just a bad one.
To Coolant Leak
