Alternator Problem
Old Mar 15, 2006 | 10:07 PM
PairOf80s's Avatar
PairOf80s
Default Alternator Problem
Here's one I've never seen...until today.
I was driving my old '77. It's a car that is in really rough condition and has close to 150,000 miles (estimated). I started having a problem with the alternator. I heard a bit of a noise. Then my voltmeter dropped to below 13 volts. Just before parking it at my destination it started charging again.
When I later started it, the voltmeter reading was normal. Sitting at a light after driving eight miles I heard metallic banging, the voltmeter dropped like a rock, and the GEN light came on. So much for that alternator! I figured I could limp home on just the battery. Probably true, but I couldn't without a water pump! Yep, it threw the only belt turning the water pump.
Once I got it parked and popped the hood I couldn't believe my eyes. The alternator pulley was gone!!
This just hasn't been my week!
Old Mar 15, 2006 | 11:02 PM
Higs's Avatar
Higs
Must be the moon! Mine locked up tonight, threw belt, got hot. Boy when they go you think the pistons are coming to shake hands with you.
Old Mar 16, 2006 | 09:13 AM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
I just love openign the hood and finding things missing,
when my last alternator went (bearing froze up), I also had to limp home with an eye on the temp gauge since my vette only has one belt, man that 327 gets hot fast at least I knew for sure the temp gauged worked for the full range
tim
To Alternator Problem
