compression test with engine out?
Old Mar 15, 2006 | 10:30 PM
tonyk72's Avatar
tonyk72
Default compression test with engine out?
Is this possible w/o firing up the motor?
Old Mar 15, 2006 | 10:35 PM
big_G's Avatar
big_G
Yes, bolt up the starter and hot-wire it.
C3w4sp's Avatar
C3w4sp
you wouldn't fire the motor to do a compression test with it in the car.
you will have to crank it over, dunno how you accoplish this while on a stand
Old Mar 15, 2006 | 10:37 PM
VETDRMS's Avatar
VETDRMS
Yes, you can crank it over, but your readings will be low as the rings will not seal as well as it will when it is hot.
Old Mar 15, 2006 | 10:40 PM
tonyk72's Avatar
tonyk72
Doh!
Would bolting up the starter & hot wiring it do the trick?
Anybody ever do this on an engine stand?
Old Mar 15, 2006 | 10:47 PM
houstonvett's Avatar
houstonvett
St. Jude Donor '09, '24
Sure can, get a pair of jumper cables and run 4 ga. sized wire to the starter motor and a small wire to the solenoid. Negative side of the battery cable to the block and both wires to the positive side of the cable. This should spin the starter enough to get your compression check done, houstonvett
Old Mar 15, 2006 | 11:00 PM
C3w4sp's Avatar
C3w4sp
if you had an engine stand that bolted to the motor mounts, like a storage stand, speedway has them like 40 bux.
most engine stands bolt to the block at the bell housing bolt holes. the flywheel / flexplate will have to have clearence to spin. either way make sure its stable and seriously held in place, take all the spark plugs out. use a fully charged battery, reg up a switch between bat and starter, crank with gauge installed in spark plug hole untill you reach max reading. repeat all cylinders. VETDRMS is right the reading will be low but the key is consistancy from cylinder to cylinder.
dunno how dangerous it is, never tried it, dunno if it would need oil or not.
Old Mar 15, 2006 | 11:26 PM
houstonvett
Can do when taking the motor out with a Porta Crane or cherry picker. Just take the belts off and plugs out. One person should be able to keep the motor from moving around while turning the starter over. Would pre lube the bearings with an oil pump primer before spinning the motor, houstonvett
Old Mar 15, 2006 | 11:33 PM
C3w4sp's Avatar
C3w4sp
as long as you don't cover the intake with a lifting bracket, the reading would not be accurate.
Old Mar 16, 2006 | 08:21 AM
shafrs3's Avatar
shafrs3
Originally Posted by tonyk72
Doh!
Sure it's doable. You can test fire, break in a cam and check for leaks on an engine stand, I did this on a fresh rebuild. You need to take the precaution of bolting it down to the concrete floor though. you wouldn't want the rapid spin up of the reciprocating assembly to cause the motor to do unwanted acrobatics if you decide to fire it. Spinning it with just the starter could be done without securing it.
And a compression test can be done on a cold engine.
Yes, and open the throttle plates for the same reasons.
Old Mar 16, 2006 | 11:40 AM
jackson's Avatar
jackson
Default test: leakdown v. comp
Those are all good suggestions for a compression test.
However, you may find doing a "leakdown" test will yield more info and is easier to do on a stand. The leakdown tester is similar to a compression tester but the leakdown tester has TWO gages on it ... and it attaches between your sp hole & a compressed air source ( compressor). You don't spin the motor with a starter, you can do it on a standard engine stand or while suspended from a cherrypicker, you don't need a carb or intake or exhaust. With leakdown, you push compressed air into cylinder ... not pumped up by a spinning motor. Moroso as well as many others sell a leakdown tester. Probably about $50-$80.
To compression test with engine out?
