Air Cleaner - Which one?
Old Mar 17, 2006 | 11:17 AM
76custompaint's Avatar
76custompaint
They have some sweet dual snorkel systems at this place : Ram Air Box but I have no idea if they fit.
Old Mar 17, 2006 | 01:59 PM
1972warship's Avatar
1972warship
Hey torqvette, would you do me a favor and send a pic of the underside of your air filter top/lid. I have had trouble getting the K&N ones clearing my choke tower. Just wondering how thick that one is, and how flat it is.
Any help is greatly appreciated.
Old Mar 17, 2006 | 02:05 PM
BADDD's Avatar
BADDD
here's another http://www.vararam.com/streetram.html The C5 system is good.
Old Mar 17, 2006 | 02:34 PM
TedH's Avatar
TedH
Is there an open element unit that I can use with my existing K&N filter in my OEM air cleaner '80 L48? Wouldn't mind experimenting with an open element assembly but don't want to buy ANOTHER K&N filter to go with it. I suppose I'd need something that I can adapt to my passenger PCV pipe that pulls fumes from the crankcase.
Old Mar 17, 2006 | 06:51 PM
shafrs3's Avatar
shafrs3
Originally Posted by alanbl
This seems like a trivial question, but I could use some help. I want to replace the stock snorkel on my '72 SB - Q-Jet with an open element air cleaner assembly and looking for recommendations. I've found everything from this $29 Eckler's unit:
This is what I came up with for an air cleaner and to solve the cold air issue. It's an Edelbrock triangular unit that I built an aluminum housing around, added a rubber seal that seals to the hood to keep out hot engine air and fabricated a snorkel that bolts to the radiator support for the fresh air. I sectioned the foam piece bettween the core support and the radiator to accommodate the snorkel. That accordion piece is from a C4 ZR1. It all fits under the stock LT1 hood and it just might fit under the small block hood as well.
Old Mar 17, 2006 | 06:59 PM
enkeivette's Avatar
enkeivette
Originally Posted by shafrs3
This is what I came up with for an air cleaner and to solve the cold air issue. It's an Edelbrock triangular unit that I built an aluminum housing around, added a rubber seal that seals to the hood keep out hot engine air and fabricated a snorkel that bolts to the radiator support for the fresh air. I sectioned the foam piece on top of the core support to accommodate the snorkel. That accordion piece is from a C4 ZR1. It all fits under the stock LT1 hood and it might just fit under the small block hood as well.
Very trick, I'm impressed.
Old Mar 17, 2006 | 07:01 PM
enkeivette's Avatar
enkeivette
My Mighty Demon has no choke tower. I'll take a pic later...
Old Mar 17, 2006 | 08:51 PM
1972warship
I appreciate it.
Old Mar 18, 2006 | 09:39 AM
shafrs3's Avatar
shafrs3
Thank you, patent pending.
Old Mar 18, 2006 | 10:45 AM
alanbl's Avatar
alanbl
This is what I came up with for an air cleaner and to solve the cold air issue. .
Great setup! But, this is how I get into trouble! Back in October, I just needed to replace my master cylinder. Well, that lead to new rotors, calipers, installing a composite monospring and new adjustable shocks. (Long story, but the rotors and calipers are on temporary hold - whew!)
Old Mar 18, 2006 | 08:18 PM
enkeivette's Avatar
enkeivette
Old Mar 19, 2006 | 12:01 AM
1972warship
I do appreciate it. Just goes to show what type of people are on this forum...helps someone out that you don't really know.....
Again thanks.
Old Mar 19, 2006 | 05:28 PM
  #33
enkeivette's Avatar
enkeivette
Again thanks.
Old Mar 29, 2012 | 01:19 PM
  #34
AV8RSVT#1's Avatar
AV8RSVT#1
Default Post revival
I want to but an open drop base filter assy. Stock "72" small block" I see different size drops. My question is what size drop do I need to clear my Q-jet and choke??
