no way. They are aluminum or some lightweight alloy.
Probably about 6 pounds per unit.
I wouldn't give up pop up lights to save that wieght.
Hell yeah ! Popup lights are so cool on c3 vettes.
the satisfaction that comes from pulling the little **** and seeing the vettes open its eyes from the drivers seat is great!
Schloop...tunk..tunk..
A few years back I had a small block V8 Vega, and talk about a nose heavy pig! And this was a car that weighed only 2400 lB. I swapped in a set of trickflow aluminum heads, that took off about 75 lbs. Man what a difference that made in handling, not to mention the extra horses. In my opinion, what else can you do for a grand that'll remove 75 lbs off the nose and add 50 horsepower.
I removed all of my headlight assembly and replaced it with about 2lbs of hardware on each side (not including the actual bulb). I just used almost the same design of the headlight bucket for the L88 headlights. Picture is in my sig.
