brake bleeding sequence
Old Mar 18, 2006 | 11:10 AM
mikewho's Avatar
mikewho
Navigator
Default brake bleeding sequence
I have recently replaced all calipers and pads. Still have soft pedal. Have installed speedbleeders and bled brakes 3-4 times. Pedal still soft with engine running. Is the proper bleeding sequence Right Rear, Left rear, right front, left front,or as Hayes has published Lr,Rr,Lf.Rf? Any other insight is appreciated.
Old Mar 18, 2006 | 11:23 AM
shafrs3's Avatar
shafrs3
From the shortest path work out to the longest. Left front, right front,
etc. You may need to bleed the master cylinder also.
Old Mar 18, 2006 | 11:36 AM
rcread's Avatar
rcread
Most people say just the opposite. Start at the furthest point and work your way in. Personally, I suspect it doesn't matter.
Old Mar 18, 2006 | 11:52 AM
dgruenke's Avatar
dgruenke
I have always been told to start with the furthest first. Therefore, you would have had it right. Make sure you let them gravity bleed for a little bit before pressure bleeding them.
Old Mar 18, 2006 | 12:10 PM
JustForFun's Avatar
JustForFun
RR Top, RR Bottom, LR Top, LR Bottom, RF, LF
jdmick's Avatar
jdmick
Normally furthest to closest. I like to go over mine twice to be sure. Proper bleeding method is more important than sequence.
Old Mar 18, 2006 | 12:13 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i have never had luck doing it only once after a full rebuild, on the British cars i did you almost had to let them sit overnight so all the bubbles could get together.....i just bled my brakes (annual maint) using the pressure bleeder and took out about 7oz of fluid from each caliper.
Old Mar 18, 2006 | 12:35 PM
Gary's 1977 Vette's Avatar
Gary's 1977 Vette
Default Brake Bleeding
I used a power Bleeder on my '77 and it did the trick. I had trouble when I tried to do it the manuel way, it took forever and you still did not get all the air out so I used a Power Bleeder @ 45lbs pressure and it took all the air out. Like he says run a few ounces out each bleeder an you will get all the air out with on problem and with the Power Bleeder you can do it by yourself in about 30 minutes!! Takes longer to take the wheels off and put on that it takes to bleed them!!
Old Mar 18, 2006 | 12:43 PM
Blackdog 06's Avatar
Blackdog 06
Mikewho,
When bleeding the rear brake system the front of the cab should be raised higher then the rear, this will position the bleeder valve near the 12 o'clock position and prevent air from being trapped in the caliper.
Old Mar 19, 2006 | 08:24 PM
carhound's Avatar
carhound
Originally Posted by Blackdog 06
Mikewho,
I thought you raised the rear ??
Old Mar 19, 2006 | 08:27 PM
carl a's Avatar
carl a
rear left inner
rear left outer
rear right inner
rear right outer
front left
front right
hope this helps
To brake bleeding sequence
