carbuerator gurus
CFM = (Redline x Cubic inches x volumetric efficiency)/3456.
Most well-built street/strip engines with moderately high compression ratios can be estimated at a 90% volumetric efficiency, or 0.90. And since 502's have the same stroke as a 454, if you're running a cast crank and cast rods, you probably have about a 6000 rpm redline. Based on these assumptions:
CFM = (6000 x 502 x 0.90)/3456 = 784 cfm
So, you can go with some of the standard sizes, stay with a 750 for the throttle response, step up to a 775, or move up to an 800. But an 850 is probably going to be overcarbed. Especially being a mechanical secondary carb. With a mechanical secondary, it's better to be less carbed than more carbed.
I'd say stay with your 750, it'll be perfect, especially for the street. This is one area where bigger isn't necessarily better. If you change to a vacuum secondary carb, then go ahead and use the 850, because the engine will only use what it needs and it's a more forgiving carb. Double pumpers are not the least bit forgiving. That's why you go a little smaller with a DP generally.
