Normal installation, sent drive shaft back for balancing and smaller u joints.
Operation seems normal except for vibration coming through the shift lever at around 4000 rpm in any gear.
Any idea as to what is causing this?
Reason: Inadvertent Indictment of Keisler
Will..did you just put the trans. in? Did you have an auto before the Keisler? If the vibration is RPM related, it is from the engine, flywheel or clutch, IMO.
also could be from the drive shaft. contact keisler and tell them about the problem.
Can't be from the driveshaft if it only happens at 4000 rpm, unless you've been driving that beast at about 150 mph. Try revving it up to 4 grand in the driveway, if you feel the vibration there its definitely in the engine/flywheel/clutch assembly.
Take the drive shaft to your local drive shaft (driveline) builder and have him check the balance. An unbalanced drive shaft will only vibrate badly at a resonance frequency (speed). Keisler shipped a lot of unbalanced drive shafts for a while and never recalled the suspected ones!
If the vibration is at 4,000 rpm in any gear, the problem is not the driveshaft.
John this has been addressed SEVERAL times already. About 9 months ago we did find out that we were getting some drivesahfts that were not properly balanced. Mr Keisler, who is an engineer, went to the driveshaft manufacturer and personally inspected their balancing equipment. He found that one of the machines had a part that was out of spec, and some of the shafts spun on that machine were not balanced properly. This was corrected and the company put new Q/A guidelines in place to prevent the problem from recurring.
Only a few customers received defective shafts. Any customers who had problems received a new driveshaft or we paid to have theirs balanced.
Instead of reading the thread and raising the flags
you could have tried answering his question just a thought
Yeah..let's get back on topic..
It could be shift linkage bushings...or some "hard" bushings somewhere transmitting more vibration to the shifter...you might check shift linkage bushings first..to see if they are "hard" or soft...then look at tranny mount...
My 78 shifter "buzzes" at 3500 rpm in 4th only...so I just speed up..or drive just below...but know my shift linkage bushings/shift rod seals need replacing...
Easier said than done, the linkage is internal in these boxes.
OOPS...was thinking Borg Warner...ok...but vibration still can be transmitted by some hard mounts in the driveline..tranny mount..engine mounts,etc..and the shifter is picking it up...
Ran it up inthe driveway today. Slowly revved from idle to 4000 with shifter in neutral.
Vibration is felt though the seat and floor boards starting at about 2700 and gets progressively worse. Not real bad at 4000 but definitely not normal.
interesting, i have a vibration around 3000 RPM. nothing major but it's there. while i also have a keisler tranny i don't know what it is. for all i know i have a tire out of balance. still driveshafts, flywheels, clutch plates. there is a LONG line of suspects and to tell the truth it's not enough for me to bother chasing right now.
Wonder if you had the flywheel and clutch balanced while you had it apart? My ballancer says that normally Centerforce clutches are on the money but ocassionally finds one that is off. Did you dial in your bellhousing? I'm thinking about a Tremec for my 68.
