Heat shield missing, causing problems?
Old Mar 18, 2006 | 10:16 PM
76project's Avatar
76project
Default Heat shield missing, causing problems?
Anyone running stock rams horn manifolds with out the stock heat shielding? Is it causing problems with spark plug wires melting or anything else? Most of my heat shielding is missing and I really do not want to replace it. Thinking of headers down the road but not yet.
Old Mar 18, 2006 | 10:41 PM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
Default Heat shields
No heat shields here. 350 SB no problems.
Old Mar 18, 2006 | 11:33 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
You may need high temp plug wires if you are having a problem. Most of the quality ones will be high temp. The silicon ones won't burn or melt, but I have seen them dry & crack if permantly laid on the exhaust.
Old Mar 18, 2006 | 11:51 PM
SIXFOOTER's Avatar
SIXFOOTER
My 77 used to eat AC hoses, ended up wrapping them in that silver backed heat resistant fabric
Old Mar 19, 2006 | 01:55 AM
chris75stingray's Avatar
chris75stingray
my 75 burns the 3,4,5,6 boots .im using cheap wires though.
To Heat shield missing, causing problems?
By Michael S. Palmer | 2026-05-22 12:13:46
