th400 modification
Old Mar 18, 2006 | 11:46 PM
Hinz-73's Avatar
Hinz-73
Default th400 modification
Has anyone tried the B&M Shift improver kit on their th400?
I'm considering it and would like to get your feedback.
Good modification or not?
I am considering the B&M "stage 1, RV / Heavy Duty" kit.
Thanks.
Old Mar 19, 2006 | 02:13 AM
VETDRMS's Avatar
VETDRMS
Yes, I have it on my TH400 in whatever the highest setting is and it has worked well, I noticed a difference when I had a tight torque converter, but now its so loose you seldom feel it shift..lol
Old Mar 19, 2006 | 10:38 AM
Hinz-73's Avatar
Hinz-73
Thanks for the reply.
Anyone else?
Old Mar 19, 2006 | 10:57 AM
GUSTO14's Avatar
GUSTO14
Originally Posted by Hinz-73
Has anyone tried the B&M Shift improver kit ...?
Good modification or not?.....
Thanks.
Yes... I believe it's one of the easiest and least expensive ways there is to wake up the performance of an automatic. I did this in the past on a number of Fords I have owned but have never done it on a Chevy. The results were immediate and very impressive. (My 289 Falcon could chirp the tires easily in 3rd gear.) It is an easy modification that any handy wrench can accomplish.
I also chose those times to install a drain plug in the trans pan. Find an area of the pan that will not interfere with the valve body or filter and weld a 3/8" thick 1" square plate inside the pan. Then drill and tap it for a standard drain plug and life will get much easier...
Good luck... GUSTO
Old Mar 19, 2006 | 11:15 AM
Hinz-73's Avatar
Hinz-73
Default .
Thanks Gusto.
I am planning on doing the drain plug at the same time.
I am somewhat concerned about the increased pressure the transmission will generate, however, the trans is relatively new. Ony 1000 miles on it to date.
Bret
To th400 modification
