Temp gauge
Old Mar 19, 2006 | 10:49 AM
mensch53's Avatar
mensch53
Default Temp gauge
I was driving in today on a nice, sunny Florida morning, when I looked down and noticed that my temp gauge was pointing straight down. Pulled over and popped the hood. Didnt feel especially hot. Car on or off, the needle points straight down. Think this is a connection somewhere or is the gauge shot?
Old Mar 19, 2006 | 03:29 PM
SIXFOOTER's Avatar
SIXFOOTER
find the temp sensor and check it out
Old Mar 20, 2006 | 05:28 PM
mensch53's Avatar
mensch53
Thats the plug with the wire in the intake, right? How do i determine if it is bad?
Is straight down the rest position if something is wrong electronically?
Old Mar 20, 2006 | 07:14 PM
marshrat99's Avatar
marshrat99
On my 79, the temp sensor is in the head between #1 & #3. Note that the wire to the sending unit is a ground wire, not a hot wire, and the hotter the engine then the more ground is sent to the temp guage. To check, disconnect the wire from the sensor and then ground the wire with the key on. Your temp guage should peg out in the hot range. I can't tell from your description if your guage is reading way low or way hi. If it is pegged way lo, then grounding the wire should cause the needle to move. If so then the sending unit is bad. If the guage is already pegged way hi, then probably the wire from the sending unit to the guage has shorted out against something.
Old Mar 20, 2006 | 07:27 PM
enkeivette's Avatar
enkeivette
How can it be a ground wire? Isn't the plug grounded to the motor already once it is screwed in?
My temp sensor has done this before. Before you start investing time diagnosing, I would just replace it, and see if that fixes the problem.
Normally the sensor is screwed into the head, but some people, like myself have relocated it to the intake manifold.
Old Mar 20, 2006 | 07:34 PM
SIXFOOTER's Avatar
SIXFOOTER
that sensor is on the ground side of the guage, grounding the wire will give you some meter deflection. Mad has a section on calibrating your temp sensore, look on there to see how to test the sensore, it involves heating up the sensor up in a pan of water while measureing the resistance on the sensor, simple actually.
Old Mar 21, 2006 | 09:41 AM
mensch53's Avatar
mensch53
Its actually not pegged anywhere. The needle is pointing to about 5 o'clock over the "T" in "temp."
Old Mar 21, 2006 | 10:26 AM
mensch53's Avatar
mensch53
Sorry, I should have been more specific...I have a 69. The intake is off of a 67 Camaro 327. Pretty sure the plug in the intake toward the front on the drivers side with the wire coming out of it is the temp sensor.
So, based on what I have read here, the question is, can I assume the gauge is shot if the needle is pointing at 5 o'clock or is that a position that could be caused by an electrical problem?
Old Mar 21, 2006 | 11:57 AM
Kid Vette's Avatar
Kid Vette
Temperature sending unit.
The search function is a wonderful thing.
Old Mar 21, 2006 | 12:04 PM
mensch53's Avatar
mensch53
Ah, thats great. Must have been using the wrong search terms. Thanks, Kid Vette and everyone else. Sounds like I have my project for this weekend.
Old Mar 21, 2006 | 12:22 PM
Kid Vette's Avatar
Kid Vette
Glad to help!
Old Mar 25, 2006 | 05:13 PM
mensch53's Avatar
mensch53
Default Update
After doing all the tests outside instrument panel, I determined that it had to be something in that panel. Finally built up the will to tear into it and found that the wiring harness on the back of the temp gauge had come off. Not sure how something like that works itself off the prongs, but that was the problem. Plugged it back in and the needle jumped to life. Just glad it wasnt a bad guage or worse, a bad wire.
Thanks for the help...
Old Mar 25, 2006 | 08:00 PM
Kid Vette's Avatar
Kid Vette
SUCCESS!!
To Temp gauge
