Any way I have to replace the front light harness while everything is a part, bubba spliced in a red wire after the horn relay to the front flashers and my temp guage dosen't work, after replacing the sensor.
So I guess I can get up throught the fender grill area to get it disconected, but is there any road blocks to getting it unplugged, or worries about the plug on the firewall breaking?
Access to the firewall connection is tight, but getting it off is pretty basic. There are two harnesses attached here, the engine harness, and the forward light harness, they are both held on by the same bolt in the middle. Remove the bolt, and unplug the harness, it's as smiple as that. BTW, I have the original and unaltered wiring harneses from my 72 for sale , if you are interested, send me a PM about it.
