Tach not working
Old Mar 20, 2006 | 10:10 AM
blue by you's Avatar
blue by you
Default Tach not working
Ok guys here is story. 71 350 4sp mech tach installed new gear and the needle bounced now it doesn't move.The cable is free and does not seem to be broken.
Old Mar 20, 2006 | 10:20 AM
GTR1999's Avatar
GTR1999
Did you replace the main shaft in addition to the gear? Also the replacement gears on the market now are,hum what that's word....junk. Sorry but most of the ones I used were really not machined correctly, I had to return them. They bound up by hand,engine power would have stripped them in 30 seconds. You're going to have to pull the distirbutor and take a look at what you have going on there.
Old Mar 20, 2006 | 10:24 AM
jbroughton's Avatar
jbroughton
There is a cross gear inside the distrbutor where the tach cable screws into the side of the distributor. This gear meshes with teeth on the main distributor shaft. The teeth are probably stripped on the cross gear, and possibly on the main shaft as well.
Been there, done that!
Jeff
Old Mar 20, 2006 | 12:34 PM
C3 4ME's Avatar
C3 4ME
Can you chuck up the cable in a drill and see if the tach works? I've done that to diagnose speedo cable problems, but I've never had a cable drive tach, so I don't know, but maybe that can help you track the problem.
Old Mar 20, 2006 | 01:25 PM
jackson's Avatar
jackson
Yes ...
HOWEVER ... run the drill in REVERSE for tach drive ... pull cable out of distributor & Gently chuck cable's core into drill motor ... spin drill in REVERSE ... if drill is running 600rpm ... the tach should read about twice that ... 1200rpm.
Old Mar 20, 2006 | 04:02 PM
blue by you
I replaced the cross gear I can spin the cable and the needle moves but when it works it bounces like there is no tension on it.
Old Mar 20, 2006 | 08:16 PM
Allen_396's Avatar
Allen_396
I just had the same problem today in my '69. Tach was working, now it's not.
This post was helpful. I pulled the cable and spun it and the tach wants to move, so I assume the problem is in the distributor.
What part(s) do I need and how do I do it once and correctly? Any help would be appreciated.
Thanks!
Old Mar 20, 2006 | 08:38 PM
carl a's Avatar
carl a
is the thrust washer in? it keeps the side gear meshing correctly with the drive,the cut of the gear makes the side gear force outward,,against the thrust washer,,no thrust washer,,drive and or side gear wipes out....4 dollar part
Old Mar 20, 2006 | 08:57 PM
Allen_396's Avatar
Allen_396
Is there a thrust washer on a factory original setup? Is it a reusable item? How do you make sure to get one if a tach side gear is ordered?
Thanks!
Allen
Old Mar 21, 2006 | 08:21 AM
blue by you
Yes the washer is in I have the plastic pin that goes in before the gear,whar does that do and is there a adjustment on the tach it self.
To Tach not working
