Oil filter relocation
Old Mar 20, 2006 | 02:17 PM
7t6vette's Avatar
7t6vette
Default Oil filter relocation
Here's the scoop.. I have a 383 stroker in my 76 vette. The oil pressure runs at about 60-65 psi when cruising. 40 psi when idle . After running down the highway at about 70ish for awhile the pressure is still around 60psi but when I slow down to idle it drops to around 30. Let it sit for awhile and it's back up to 40 when idle. I was going to do is add a oil radiator but it looks like if I add the "sandwich filter addapter" my oil filter will almost touch my header probably making it impossible to get a filter on or off. Is it possible to use a oil filter relocater along with the oil radiator? I have been using Castrol 10w30 during the winter and 20w50 during the summer. Is this normal for the temperature??
Old Mar 20, 2006 | 02:56 PM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
Part of why it does this is that after motoorvating down the road for a while the oils is sitting on top of the engine before draining back to the block. After is sits for a while the oil makes its way back to the pan. and the pressure returns to normal
Old Mar 20, 2006 | 03:09 PM
BerniesVette's Avatar
BerniesVette
You should be able to find all the parts you need at Summit or Jegs to relocate your filter and addca filter.
Berne
Old Mar 20, 2006 | 08:28 PM
markdtn's Avatar
markdtn
You might also look at a mid-90s 4.3 4wd Blazer for oil filter relocating parts if you have access to any.
To Oil filter relocation
