EFE-TVS Switch
Old Mar 20, 2006 | 10:16 PM
bmankin's Avatar
bmankin
Default EFE-TVS Switch
I'm changing the Carb on a 1977 to a performer. Does the EFE-TVS Switch need "timed" vacuum or constant vacuum like the EGR? I had no way to check it before I pulled the old carb. I will be rebuilding my Q-jet soon so I'm trying not to make to many changes because it must go through a emission test.
Old Mar 21, 2006 | 09:08 AM
chevylit's Avatar
chevylit
On My 77 with quadrajet the vacuum source is the vacuum port
just above the fuel inlet which I think would be a 'timed" vacuum
port.
Old Mar 21, 2006 | 12:53 PM
Rich's'78's Avatar
Rich's'78
The EGR must be ported vacuum so it only 'sees' vacuum when the throttle is partly open / during cruise. The EFE needs manifold vacuum so it closes the valve as soon as the engine starts.
To EFE-TVS Switch
