Need Distributor help Fast
Old Mar 21, 2006 | 02:11 PM
Silver00V6Camaro's Avatar
Silver00V6Camaro
Default Need Distributor help Fast
Ok so i am trying to put on my new hei recurve kit and the old springs and weights are rusted so i put some oil on there to loosen them so so nothing would break well guess what the two poles that the springs attach to broke in the middle of the distributor where the middle weight is. So my question is can this be replaced or do i have to buy a new distributor. need help fast
Old Mar 21, 2006 | 02:16 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
All you need is a new dist shaft installed into that existing housing.
Old Mar 21, 2006 | 02:19 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
I may be cheaper to get a rebuilt unit from a parts store rather than hunting down the individual parts.
Silver00V6Camaro
thanks
Old Mar 21, 2006 | 02:23 PM
Silver00V6Camaro
I have a new cap, rotor, vacuum advance, accel hei super coil, and recurve kit. So i dont want to buy a new dis if i can help it. Where do you get the dist shaft. thanks
Old Mar 21, 2006 | 02:26 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
you can get an HEI cheapo unit for $69 on ebay
Old Mar 21, 2006 | 02:36 PM
burners's Avatar
burners
Cruise-In V Veteran
You should be able to get an entire distributor from a junk yard for $5-15. Remember, any Chevy V-8 from 1975 up to about 1983 will use the same unit.
Old Mar 21, 2006 | 03:37 PM
Silver00V6Camaro
can you buy just the shaft. I have had no luck with the junkyards here around huntsville to find a dist.
Old Mar 21, 2006 | 04:32 PM
73'454folendore's Avatar
73'454folendore
I agree with finding a used one for parts but I had the same situation myself with the pin breaking loose. This is the bubba way out but I used some JB weld and set back into place and let it sit for a day. That was a year ago and have never had a problem since. You can't find that pin as a part anywhere.
Old Mar 21, 2006 | 05:52 PM
Silver00V6Camaro
Well where ever you guys can find a dist. for 5-15 bucks more power to you i called everywhere in huntsville and the cheapest one i found was 50 bucks.
Old Mar 22, 2006 | 08:30 AM
jackson's Avatar
jackson
Default Pins are Standard Ign P/N DG-50
The weight pins ARE available NEW. Go to any local parts house that sells "Standard Ignition" brand (aka "Standard Motor Products Corporation") ... ask for part number DG-50. If the center is loose on shaft ... simply have it tack-welded.
-edit- Before welding on top of an HEI distributor shaft ... you MUST remove the ignition module ... the pickup can stay in place so long as module has been removed and the pickup's terminals are not touching one-another.
To Need Distributor help Fast
