Woo Hoo i got it running
Old Mar 23, 2006 | 01:17 PM
Silver00V6Camaro's Avatar
Silver00V6Camaro
Default Woo Hoo i got it running
thanks for everyones help i doule checked everything and found out my dist was 180 out got in line and bam on the first try it fired and the timing was close to boot so thanks for everyones help.
Old Mar 23, 2006 | 01:24 PM
MsVetteMan's Avatar
MsVetteMan
Congrats, now go have fun, and drive!!
Old Mar 23, 2006 | 01:36 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
I bet you feel better now.
Old Mar 23, 2006 | 01:42 PM
JustForFun's Avatar
JustForFun
if a dist was 180 out, would it still be possible for it to run? Im sure it would be rough, but would it even crank?
Old Mar 23, 2006 | 02:15 PM
Silver00V6Camaro
in my case it just turn over and then backfire every once and a while. and yes i feel a lot better know that its running and that i am not as dumb as a thought i was.
Old Mar 23, 2006 | 02:24 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
RUN? Heck no. Fire? yea - enough to backfire out the exhaust and usually the carb too. If there's enough fuel charge in her, it can bust the start housing too.
Old Mar 23, 2006 | 02:32 PM
Silver00V6Camaro
Old Mar 23, 2006 | 03:21 PM
PatsLs1vette's Avatar
PatsLs1vette
Congrats now go have some fun
Old Mar 23, 2006 | 04:11 PM
gonzo14's Avatar
gonzo14
YEEEE HAAAWWWW "Give that Man a CIGAR!!" Git' yo' self out their and drive dude!!!
Gonzo
Old Mar 23, 2006 | 04:24 PM
dgruenke's Avatar
dgruenke
Now comes the fun part, the test drive.
Old Mar 23, 2006 | 07:25 PM
Silver00V6Camaro
well got out and drove it and now it needs some timing adjustments. Any help on input on the timimg would be great it has 12 inital and 36 with advance hooked up. i have an aggressive cam it is the edelbrock performer rpm and i have an auto. When the car is in park the idle is at 1200 and in drive the car will die if you dont give it some gas or put it in neutral and the idel is at aobut 550 600 so any help with the timing is appriciated. thanks again
Old Mar 23, 2006 | 09:11 PM
Perfomer's Avatar
Perfomer
What stall speed converter do you have? Set timing with vacuum advance removed. Set timing at 38 degrees at 2800rpm then plug the vaccum advance up. Set your idle at 900 in park .This should let you idle at 700 in drive. If you dont have a stall converter you might have a problem getting it to idle . If you need help I live in Athens. I will be at the drag strip in Huntsville on Sat. Look for the car hauler made from a retired U-haul van Dwight
Old Mar 23, 2006 | 09:20 PM
Silver00V6Camaro
It is supposed to have a 3000 stall but when i foot break the car starts to move at about 2500-2700 rpm. Also can anyone recommend a spring combo out of the mr. gasket kit right now i have the silver springs in.
Old Mar 23, 2006 | 09:34 PM
Perfomer's Avatar
Perfomer
What ever sprins that make the timing at 38 degrees at 2800 rpm. You may have to use a combo of two colors . That about right on the converter for a 3000 stall . Does it idle now with the car in drive ?
Old Mar 23, 2006 | 09:37 PM
Silver00V6Camaro
barley because i dont have the timing set up just right but even with the old dist at lights i would have to put it in neutral because it would try to stall. Right now it idles at about 550- 500 maybe in gear. I think once i get the timing right it will be alot better.
Old Mar 23, 2006 | 09:46 PM
Perfomer's Avatar
Perfomer
I had the same problem with my race car , Bump the timing up and it should start acting right .
Old Mar 24, 2006 | 01:35 PM
Silver00V6Camaro
thanks runs like a champ.
Old Mar 24, 2006 | 01:42 PM
kaamacat's Avatar
kaamacat
The other thing that sometimes happen, and its easy to do in a crowded area, is to accidentally switch #5 and #7. The engine will start and run but backfire. They are right next to each-other physically, and also in the firing order.
BobR
To Woo Hoo i got it running
