Opinions on future engine project
What I want to do is the 454 small block (motown block
I'm sure I could probably get a big block for less money but I like the fact that the small block will fit right in ALMOST perfectly with less mods needed to fit it. The complete engine from World Products says 600hp on 91 octane out of the box, I figure I could probably tune it down a touch and still be over 500hp and run 87 octane and still get possibly over 20mpg on the highway, with an overdrive.
Comments, opinions? This isn't a project that's going to happen any time soon but I'd like to actually plan this way ahead of time so I'm not running around like a chicken with its head cut off.
I just talked to my local engine builder that rebuilt my 350 and talked to him about making a 454 small block and he's estimating the whole long block for under $3k. He admits it might not be as great of quality as the World Products one because he's not sure what parts they use but he assured me that it'd still be a strong street motor.
Amazing what knowing local shops can do for ya.
At the moment im looking at this:
http://www.shafiroff.com/ultrastreet/434_595_engine.asp
I think it make sense to leave material enough for at least one rebuild
What I'm going to have to do first is the transmission and rear end, though. I think I may just go with the 2004R, instead of the TKO-600, just so I don't have to worry about tearing up the rear end as easily. I'll definitely need to beefen up the differential to handle the power, though. Think I should stick with the 3.08 rear gears? This is a street monster, remember, not a drag queen.
Since I now know that I can have this massive mouse motor built for half the cost I originally thought it would this project may move up much closer than I thought. The whole project may end up costing under $11k with the transmission and rear end. (Probably cost $3500 for the engine, $3000 for the fuel injection, $1500 for the transmission, $1500 for the rear end)
My reasoning behind the use of lower octane isn't that I'm trying to be cheap in the long run but to make it easier to drive around. Sure I can build it up to do 600hp on '91 octane but I would settle just fine to build it to 500hp and run it on 87 octane. More of a bragging rights, in my opinion. Some ricer says he has 400hp and he says with premium, well I can do 500hp on regular gas, who wins now? I haven't gotten in to the cam specs and such yet as I'm still in the basic plan of it. You can make suggestions though.
The order of operations for this project is obviously going to be transmission, rear end, then the engine so the rest of the car is prepared for the massive amount of power. Would the level 3 Bowtie 2004R be able to withstand that power, or should I look to a better builder of them? I'd prefer to stick with a transmission builder in southern california, in case something goes wrong.
