Final Eng. Set Up
Old Mar 24, 2006 | 05:42 PM
sly vette's Avatar
sly vette
Default Final Eng. Set Up
Well after alot of research,I've come up with the final componants for my eng. First I have a 350 4 bolt main .060 over w/9.7:1 cr. I'm going to now install cast alum. flat top pistons(w/ small valve relief,like a stock top),a Edelbrock alum. manifold,a Edelbrock 750cfm carb.,Speed Pro cam(.443/.465 214/224),headers. and the plus side to this is that,when I pulled the heads(cast camels) I found that I have 2.02" valves as opposed to the 1.94" valves that I thought I had. I was wondering how much benefit I can expect from the larger valves W/ported(unpolished)heads? Really the reason for posting this is get some input as to my decisions due to the fact that the help I received on this forum helped alot,especially with the cam.(Thanks Cardo and Jackson). Also I don't know if this is poss but,can anyone give me a rough estimate on my anticipated H.P.? Thanks again guys,the forum comes through for me again.
Later,
Sly
Old Mar 24, 2006 | 08:30 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
Later,
Sly
That would be cool if this can be done. I would want to know H.P.
#'s for my setup also.
Old Mar 24, 2006 | 10:01 PM
kevinator80's Avatar
kevinator80
What do we win if we guess correctly? Sorry here I go with my humor in my own mind again.
my guess=350 as an optimist
Old Mar 25, 2006 | 12:17 AM
sly vette's Avatar
sly vette
How 'bout if you guys guess and I'll see if I can get it on a dyno when and if I have any money left over from this project. Then I'll post the results for bragging rights and maybe I can come up with some small Prize.
Later,
Sly
Old Mar 25, 2006 | 08:59 AM
jackson's Avatar
jackson
w/9.7:1 CR AT CRANKSHAFT: About 330-350HP@About 5300rpm.
Well after alot of research,I've come up with the final componants for my eng. First I have a 350 .060 over w/9.7:1 cr. I'm going to now install fordged alum. flat top pistons(w/ small valve relief,like a stock top),a Edelbrock alum. manifold,a Edelbrock 750cfm carb.,Speed Pro cam(.443/.465 214/224),headers. and the plus side to this is that,when I pulled the heads(cast camels) I found that I have 2.02" valves as opposed to the 1.94" valves that I thought I had. I was wondering how much benefit I can expect from the larger valves W/ported(unpolished)heads? Really the reason for posting this is get some input as to my decisions due to the fact that the help I received on this forum helped alot,especially with the cam.(Thanks Cardo and Jackson). Also I don't know if this is poss but,can anyone give me a rough estimate on my anticipated H.P.? Thanks again guys,the forum comes through for me again. Later, Sly
Old Mar 25, 2006 | 10:38 AM
sly vette's Avatar
sly vette
Thanks again Jackson...
Later,
Sly
Old Mar 25, 2006 | 10:49 AM
Tonys96's Avatar
Tonys96
Getting it on the dyno is probably one of the more important things to do.
Right outta' the box, the parts will work together, but you'll most likely be leavin' a pile of HP and Tq on the table.
My tuners got me about 50 HP 1 jet size at a time and 1 degree timing at a time. That was about a 12% gain.
Old Mar 25, 2006 | 11:30 AM
sly vette's Avatar
sly vette
Thanks Tony.
Yeah I'm going to have to find a dyno to get it tuned to it's max potential. Whats preferred,a engine dyno or chassis dyno??? Never had any exp. with a dyno. As a kid I just slapped some parts together and drove like my hair was on fire.
Later,
Sly
Old Mar 27, 2006 | 12:08 AM
sly vette's Avatar
sly vette
ttt
Old Mar 27, 2006 | 10:41 AM
jackson's Avatar
jackson
Sly:
I got your email back ... and I tried to reply ... but when I tried to reply it keeps being returned by mailer-daemon. Is it possible the email addy you on file w/ this forum is no longer any good?
Old Mar 27, 2006 | 10:49 AM
sly vette's Avatar
sly vette
Default Send it here
sylvester123@comcast.net
Old Mar 27, 2006 | 10:51 AM
jackson's Avatar
jackson
Tried that one three times ... all returned
Old Mar 27, 2006 | 10:55 AM
jackson's Avatar
jackson
tried a fourth time ... returned also
Old Mar 27, 2006 | 10:58 AM
sly vette's Avatar
sly vette
I got them. I'll get those numbers to you and no I never heard of "quench"
Later,
Sly
Think I might go with a thinner gasket then.
Old Mar 27, 2006 | 11:26 AM
Tonys96's Avatar
Tonys96
You can use either a chassis or engine dyno.
You will find that a good engine dyno will have better instrumentation such as individual cylinder exhaust temperature pyrometers, airflow and fuel flow sensors. This will give the tuner better information to work with. Allowing them to tune both the primary and secondary sides of the carb
If you want to get everything the motor has to offer that's the route to go.
Most chassis dynos can only use an exhaust gas analyzer, rarely any kind of pyrometers or air flow measurement, so while they will get you into the air to fuel ballpark, it's only in the ballpark.
Again, "My Opinion"
Old Mar 27, 2006 | 11:48 AM
sly vette's Avatar
sly vette
Thanks Tony.
Later,
Sly
Old Mar 27, 2006 | 01:02 PM
MEGALADON's Avatar
MEGALADON
How did you figure that ???
To Final Eng. Set Up
Old Mar 28, 2006 | 09:03 AM
jackson's Avatar
jackson
Experience building limited & open circle track motors & comparison to similar engine-dynoed combos (not DD2K, not i'net lists) ... albeit a fair estimate, it is an estimate ... hence "about".
Old Mar 28, 2006 | 12:27 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default It all adds up.
. First I have a 350 .060 over w/9.7:1 cr...,Speed Pro cam(.443/.465 214/224),headers. and the plus side to this is that,when I pulled the heads(cast camels) I found that I have 2.02" valves as opposed to the 1.94" valves that I thought I had. I was wondering how much benefit I can expect from the larger valves W/ported(unpolished)heads? Really the reason for posting this is get some input as to my decisions due to the fact that the help I received on this forum helped alot,especially with the cam.(Thanks Cardo and Jackson). Also I don't know if this is poss but,can anyone give me a rough estimate on my anticipated H.P.? Thanks again guys,the forum comes through for me again.
Later,
Sly
The big gains are made with stroke, heads and cam. But the rest of the small hp gains will add up - thats how NASCAR gets mega hp from restrictor plate sb's.
So what i'm saying sly is don't worry so much. If u matched ur cam right to the c.r., heads and c.i. u are way ahead of most - it should make good pwr and yet fun to drive with little problems.
Heck look at the Goodwrench 350" crate eng. For $1300 u get a low c.r. 260hp 350". But GM now sells the same eng for $1600 at 290hp with only a cam change, no other changes, but charges us $300 more though dosn't cost GM an extra dime.
U can read Chevy Hi-Performance articles on a Goodwrench 350" build-up to over 400hp and get an idea where ur eng fits in for hp. I read it many times and still enjoy reviewing it.
But what is critical now sly is to break that cam in correctly and right away - no low rpm. If the eng won't start in less than 5 turns then stop and find out why. Believe me, changing cams again after all that work is not fun or motivating.
Good work and have some fun with that car now.
cardo0
Old Mar 28, 2006 | 05:27 PM
sly vette's Avatar
sly vette
Anything special I should do besides a good prime,proper dist. placement and a quality oil?
Thanks again Jackson and Cardo,
Later,
Sly
