Small rear end vibration at speed
To fill in some other details, this is a complete frame off resto. The trailing arms were completely rebuilt by Van Steel. The u-joints were all replaced on the original half shafts. The shafts were sand blasted and painted to pretty 'em up. The diff was drained and re-filled with new fluid but not rebuilt. The diff mount was replaced with a new rubber unit. The end play on the yokes was within acceptable limits, I think less than 4 mils. The wheels are all brand new and completely balanced. The 9 leaf spring was rebuilt and I am using KYB shocks on all 4 corners.
Any ideas on where to start looking first to determine where it's coming from?
Regards
If the drive shaft angles are not exactly the same front and rear you WILL get vibration.
My thoughts exactly. I have always thought that I was pretty close with mine but if there is a definate spec that I can check, lets hear it. I think I can fix it till it is broke.
That said, I don't know if it is possible to have the diff pinion in a C3 up that far. I am making a guage to check, I think Spicer sells one for about $300. Let me know if you buy one, I need to borrow it!
Rich
Driveshaft vibration is at 2 times the engine rpm in the 1:1 gear ( 3rd in a th400, 4th in a 4 speed, 4th in a 5speed overdrive...) so it is fairly high frequency, more of a buzz.
The aligning the drive shaft angles means making the driveshaft to yoke angles the same at both ends. You don't really care what the angle is as long as the front is the same as the rear.
People put the Diff in and don't align it and that cuses angles to be off side to side. Up and down is hard to change unless you have done a transmission swap.
The best way is one of the pinion angle protractors, but good luck getting one on the driveshaft of a C3 with the body on
I used some heavy wire, bent to the angle of one end and a lot of trial and error!
Adjust, drive...adjust, drive...
