HELP!
Old Aug 15, 2001 | 11:13 PM
Blues77's Avatar
Blues77
Default HELP!
im sure this will get booted to off topic..but if i call a lock smith i wont have $ to work on the vette!!!........... half of my key broke in the ignition and i have airbags in my 93 caprice....theres no way the other half of the key is comin out...how do i get by the airbag to the ignition?
Old Aug 16, 2001 | 12:39 AM
lyonsh's Avatar
lyonsh
Default Re: HELP! (Blues77)
This isn't really going to help you in the sense you want, but be REAL careful around airbags. If you want to remove them you have to use the EXACT manufacturers procedures or they either might activate on you (seen it happen -wasn't my car, but still scared the #$%@^ out of us) or you could damage the clock-spring and the bag won't work if you need it. Touchy little buggers.
Are you SURE you can't get that key out? I broke one off in a 66 Bel Air, and we were able to spray a bunch of lock-eze (graphite lubricant) in there and coax it out with a couple of small screwdrivers. Much easier than trying to disassemble a steering column.
[Modified by lyonsh, 10:40 PM 8/15/2001]
Old Aug 16, 2001 | 01:43 AM
Blues77's Avatar
Blues77
Default Re: HELP! (lyonsh)
hey man thanks for the warning, im really nervous about messin with it to. The key is really jammed in there. Im thinkin of takin a really small bit and drillin it out. thanks
To HELP!
