TH350 downshift cable adjustment
Old Mar 25, 2006 | 10:59 AM
vett79's Avatar
vett79
Default TH350 downshift cable adjustment
During rebuild of my Quadrajet I noticed the throttle body plate is cracked at the threaded hole for power brake vacuum. I was going to pull a throttle body off another Quadrajet but the location of the downshift lug on the throttle linkage is 1/4" further to the rear. Does the downshift cable have that much adjustment in it? Car is '79 L48/TH350.
Old Mar 25, 2006 | 11:48 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Probably. After it's together, have somebody inside the car, mash the gas pedal. Then push up on the button under the cable where it goes through the bracket. It will adjust itself.
Old Mar 25, 2006 | 12:43 PM
vett79's Avatar
vett79
Thanks............I thought so but thought I'd get another opinion before I put all together.
Old Mar 25, 2006 | 11:24 PM
77 vette's Avatar
77 vette
I was surprised at the amount of adjustment on my 77, I pulled the clip up, hooked the linkage to the carb, mashed the peddle and poped the clip back to lock it in, I think I got almost an inch
Old Mar 26, 2006 | 01:17 AM
comp's Avatar
comp
To TH350 downshift cable adjustment
