Changing Diff oil, cheap easy trick
Old Mar 25, 2006 | 07:57 PM
lowbuck72's Avatar
lowbuck72
Default Changing Diff oil, cheap easy trick
After reading several threads about changing to Royal Purple in the differential to reduce gear, I put in on my mental list. While shopping with the wife at Smart and Final last week, I ran across a plastic pump dispenser that's used for flavored syrups. It would normally screw into the top of a bottle of syrup. Since that stuff's pretty thick, I went ahead and bought one for $2.99. It worked like a charm for removing diff oil through the fill hole. I just attached about 2 feet of 3/8" rubber hose to the pickup of the pump dispenser, and after jacking up the right rear and removing the wheel and fill plug, I was able to pump out 1 1/2 quarts from the diff. After the change, gear whine was reduced 50%.
Old Mar 25, 2006 | 08:39 PM
C3Racing's Avatar
C3Racing
St. Jude Donor '07-'08
Old Mar 25, 2006 | 08:50 PM
1BAD80's Avatar
1BAD80
I use Royal Purple oil & lube on every car & motor I have.
It doe's take away the gear noise from the rearend where as it don't bother anymore.
I just warmed the bottle up, put a long hose on it put it thru the plug to the rear of the housing and squeezed it in and the old lube came out the side of the plug hole into a pan. The old lube floats on top of the Royal lube so you don't have to try to drain it first.
I done 6 Vettes the same way and everyone was glad to get rid of the gear noise. It's well worth the $$ for the lube.
Sorry I had to put in my .2005 cents worth in, but it doe's work.
Old Mar 25, 2006 | 08:51 PM
Tonys96's Avatar
Tonys96
Cool idea...wonder if the 'ol Mighty Vac hand vacuum pump would work.
Old Mar 25, 2006 | 09:35 PM
1BAD80's Avatar
1BAD80
The vac would work but with the rearend lube warmed up a little it comes right out like oil on top of water thru the plug hole.
Use a long hose, the bottle should fit just above the rear tire or close.
I used a 3/8" hose, just squeeze it in slow& make sure the hose is at the rear of the gears.
Very easy to do, just takes time being carefull letting it flow out.
You would be supprised on the motor with the R P oil they advertise a 5% improvement in HP and have the dyno results to prove it.
I tried it and now IM hooked on it.
Same with Marvel Mystery Oil in the gas, and I add 1/2 qt to the oil when changing it.
Also a Ac PF 932 2 qt oil filter, it fits 1" above the oil pan and easier to install.
Puralator & Dusch make a 2 qt also.
My Dyna 44 took 1 1/2qts to fill.
http://www.royalpurple.com/index.html
Old Mar 25, 2006 | 11:26 PM
GaryS's Avatar
GaryS
Yep. Works fine.
I would question whether some other product that is designed to pump edible fluids will stand up to something that is designed to pump petroleum products.
Gary
Old Mar 26, 2006 | 04:55 AM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Not to send in the black cloud, but the engineers at Eaton "strongly recommends" the use on conventional/mineral lubricants with their posi carriers.
Might want to reconsider the use of synthetics if you're running Eaton.
Old Mar 26, 2006 | 08:10 AM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
i use the same type of pump to pump trans fluid into my 77. i bought mine at harbor freight. works awesome!
To Changing Diff oil, cheap easy trick
