JEG'S 100-Amp 1-Wire Conversion Kit
Mar 26, 2006 | 09:02 PM
Has anyone used this. I need to upgrade my alt and was thinking of puchasing this kit. How hard is it to install this. thanks
Mar 26, 2006 | 09:20 PM
wrong way to go, stick with a 3 wire. It will work better on your car. There are several available in 100+ amp packages
Mar 26, 2006 | 09:30 PM
what do you mean 3 wire i have one bulk wire and then the regulater connection. You cant see it very good in the pic but its just a stud where the wire conncects and then where the regulator goes in.
Mar 26, 2006 | 10:16 PM
He's talking about the main battery feed wire and the two regulator wires that plug into the side of the case, that's the stock 3 wire setup.
Stick with this setup, it works better.
Mar 26, 2006 | 10:21 PM
yep, and the 1 wire setup in the jegs cat is really a 1 wire setup. Check out the MAD article if you want the details. If not, order one of these
http://www.partzfinder.com/CHROME_Al...p-7935-f6g.htm
Mar 26, 2006 | 10:52 PM
Mar 26, 2006 | 10:55 PM
im trying to figure out a way to upgrade without spending an arm and a leg i cant justify the price of the 140 amps when i only need about a 100
Mar 26, 2006 | 10:57 PM
Try snagging one from the boneyard.
Mar 26, 2006 | 11:12 PM
oops, I posted the wrong one, that was supposed to be a 3 wire
Mar 27, 2006 | 03:11 AM
St. Jude Donor '07
Mar 27, 2006 | 07:49 AM
