Dizzy advance springs
Old Mar 27, 2006 | 07:45 AM
Simmo's Avatar
Simmo
Default Dizzy advance springs
Do HEI's and points distributors share the same mechanical advance springs?
Old Mar 27, 2006 | 12:37 PM
vettfixr's Avatar
vettfixr
I could be wrong on this but I believe the points distributor springs are slightly shorter.
Old Mar 27, 2006 | 02:01 PM
CGGorman's Avatar
CGGorman
No clue, but you might get more responses if you call it by the more common name, "distributor".
Old Mar 27, 2006 | 02:25 PM
lars's Avatar
lars
No, they don't. But if you're looking to re-curve your dizzy, you can use the springs out of the same curve kit for either unit. Try Mr. Gasket part number 928G or 927G - these kits, if available down there, have 3 sets of springs. Use the two gold springs for the HEI and you'll get a very good curve.
Old Mar 27, 2006 | 05:21 PM
Simmo's Avatar
Simmo
Actually I have a points distributor (firing a CDI) and to date can only find shops selling spring kits for HEI. I need some stiffer springs as I have some advance already in at idle.
Old Mar 27, 2006 | 06:34 PM
Sky65's Avatar
Sky65
St. Jude Donor '05, '09, '15
Can you order from JEGS?
http://www.jegs.com/webapp/wcs/store...1563&langId=-1
To Dizzy advance springs
