excessive engine ping
Old Mar 27, 2006 | 11:43 AM
77STROKER's Avatar
77STROKER
Cruising
Default excessive engine ping
Any help appreciated, I have a 77, automatic trans. powered by a 383 stroker, the heads are gm performance fast burns, gm performance vortec intake with a street demon 650 carb-the car is extremely fast but when under load or take off it pings severely.i have backed the initial timing down to 6-8 degrees adv. (which is lower than the 14-16 demon recommends) with no improvement.i have tried octane booster,even cam 2.. I run the gm perf.distributor (hei) could the advance springs be too light and coming on too soon.what do you think guys?????
Old Mar 27, 2006 | 11:59 AM
gkull's Avatar
gkull
What is your total timing at 3500 rpm? You do understand that fastburn heads require recourved distributers don't you?
Old Mar 27, 2006 | 12:33 PM
vettfixr's Avatar
vettfixr
The 383 from GM with Vortec type heads specifies no more than 29 degrees total mechanical advance. If you are using a distributor set at the traditional 32 - 36 degrees you have to recurve it.
Old Mar 27, 2006 | 01:49 PM
Fevre's Avatar
Fevre
Do you have your vac adv hooked up? If so remove and drive it, if the pinging stops then it is your vac adv (need to limit it) if it does not stop then you need to back your timing off some, as the others have said the vortec comb chamber heads like a little less timing then old sytle heads but you need to recurve the dist to get max performance, will be weak off idle if you just back the timing off without recurving it
Old Mar 27, 2006 | 04:34 PM
marshrat99's Avatar
marshrat99
I had the same problem recently while I was experimenting with different springs on my HEI. My problem was that I had used too light springs and needed a heavyer/stiff set of springs.
Old Mar 27, 2006 | 06:32 PM
Older Than Dirt's Avatar
Older Than Dirt
Recurve it and try a different vacuum advance can.
Old Mar 27, 2006 | 10:01 PM
BigBlockk's Avatar
BigBlockk
What are the static compression and camshaft specs for this engine?
BigBlockk
Later.....
Old Mar 27, 2006 | 10:14 PM
big_G's Avatar
big_G
The G.M. "Fast-Burn" heads sport 62 cc.chambers. You better have a serious dish on those pistons....On my 383 with flat-tops (-5cc valve reliefs) and 70 cc chambers, I am right at 11:1 with .029 head gasket.
Old Mar 27, 2006 | 10:29 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Sound like your dynamic compression might be to high too. Octane boosters don't do a whole lot to the actual octane rating. Distributor recurve and if that don't work worst case you might have to change the cam to reduce dynamic compression. There are some posts on here about economically boosting the octane with some hardware store solvents but I haven't tried them yet. Preignition and detonation will kill your new motor. A cam change is a lot cheaper than rebuilding it again
To excessive engine ping
