Currently my car sits at 28" from ground to start of rear fender (level surface), my exhaust is just 3" from the ground around the differential. My differential is about 6-7" from the ground.
Do I need to replace my rear spring to bring my car up? Or am I riding at the proper height?
I am starting to wonder if I installed my exhaust in correctly. I have a 74 exhaust on my car. But there is really only one way for it to go on.
Does anyone have photos of their exhaust around the rear axel?
Are you running a 2-1-2 exhaust?
Not sure if mine was installed correctly either, but the Rear Y-Pipe is the lowest part of my rear exhaust.
I know that the bottom level surface of my rear license plate area is just a fraction under 15" from the ground. Does your license plate sit that high(low)?
This is what mine looks like...
it used to bottom out on speed breakers till I replaced the transverse rear leaf spring with a composite one..
now its just fine..
