breaking up under a load
Old Mar 29, 2006 | 02:36 PM
palazzopl's Avatar
palazzopl
Default breaking up under a load
I installed a new fuel pump,fuel pressure regulator set at 5.5 psi a new edelbrock 600 cfm carb and filter . the problem is when it down shifts into passing gear with my foot on it, it feels like it is starving for gas. I don't think its an ignition problem because the tach isn't bouncing around..Its an 81 with all the emission junk taken off and no cat,
Old Mar 29, 2006 | 02:56 PM
Fubba's Avatar
Fubba
Have you checked your timing? What is it set at? Pull a couple of spark plugs and see what color they are. My 71 had a problem with breaking up real bad at 3000 rpm, and an upgrade in points, coil, and condenser fixed that mess. Check those two things and that will tell you a lot.
Old Mar 29, 2006 | 05:06 PM
palazzopl's Avatar
palazzopl
timing is set a 12 btdc and it has a HEI distributer with a vacuum advance
Old Mar 29, 2006 | 05:20 PM
Jims79's Avatar
Jims79
I think the problem is the size of the carb the edelbrock 600 is a good carb but 600 cfm is too small for performance driving. around town and hwy its OK but put a load on it, drive the car hard & 600 cfm doesn't cut it. Most C1 & C2 run find w/a 650cfm but the C3's came w/a 750cfm Q-jet from the factory and you just down graded to a 600. I know this because I did the same thing & when I redo my motor the edel 600 is going up for sale & a q-jet 750 is going back on.
Old Mar 29, 2006 | 05:21 PM
Fubba's Avatar
Fubba
Whoops! Guess I didn't notice it was an 81. My bad. What's your total timing and when is it all in? Try and check the plugs. Secondary's on those are usually set right. If you're running lean when getting on it, you're usually running lean all the time. Same goes on the rich side of things.
Old Mar 29, 2006 | 05:23 PM
Fubba's Avatar
Fubba
Originally Posted by Jims79
I think the problem is carb the eldebrock is a good carb but 600 cfm is too small for performance driving. around town and hwy it OK but put a load on it drive the car hard & 600 cfm doesn't cut it. Most C1 & C2 run find w/a 650cfm but the C3's came w/a 750cfm Q-jet from the factory and you just down graded to a 600. I know this because I did the same thing & when I redo my motor the elde 600 is going up for sale.
When I desktop dynoed my car, upgrading to a larger carb did not give me any more power. Now that it's tuned well, it runs great
Old Mar 29, 2006 | 05:28 PM
Jims79's Avatar
Jims79
I don't know about more hp but top end is what I think the smaller cfm carb is lacking. Like I said my car runs great around town & hwy and I'm happy w/the 600 edle but when I put a load on it she feels like can't get enough gas.
Old Mar 29, 2006 | 05:48 PM
palazzopl's Avatar
palazzopl
I had a old 600 edelbrock on before and I didn't have these problems..any ideas on what plugs to use ,,it has a mild cam and headers so I don't think the stock plugs are hot enough..
Old Mar 29, 2006 | 11:54 PM
Fubba's Avatar
Fubba
It seems like it pulls good until about 5000 to 5500 or so. I don't race, and my motor is only built to hold 6200 rpm. It's just enough carb for me.
Old Mar 29, 2006 | 11:59 PM
MsVetteMan's Avatar
MsVetteMan
Pull a couple of plugs and check them. I'll put 10-1 on it that you are to rich, not to lean.
Been there.
Old Mar 30, 2006 | 08:51 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Did you check your float bowl levels? If you're starving for fuel under high RPM's that could be the problem. Just a thought.
Old Mar 31, 2006 | 09:36 AM
palazzopl's Avatar
palazzopl
took it for a ride today . it had a slight hesitation when it was cold then it ran fine after it warmed up. I pounced on it a few times and it didn't bog down or break up..its starting to drive me nuts. going to try it later when it gets warmer this afternoon..its suposed to be in the 80's ..I did notice that the fuel filter gets very hot, its mounted above the valve cover about 6 inches before the carb.
Old Mar 31, 2006 | 10:21 AM
MsVetteMan's Avatar
MsVetteMan
You check a plug yet? You may just merely need to rejet and rerod. It's very simple to do on the EB carbs. Pull a couple of plugs.......that will tell the story!! Than you will know which direction to go.
Check what jets and rods your old carb had, and compare it to the new carb. New EB's are shipped in the middle......which from my experience is way to much for a stock motor.
To breaking up under a load
