corvette bigblock manifolds. the truth?
I just had a chat with a long-time chevy mechanic/rodder and he said that bigblock, corvette-specific manifolds work very well, and that headers would not make any worthwhile performance gains, especialy with stock-style pipes that are squashed at the rear. He said that headers are not worth the expense, hassle, leaks, or the risk of bottoming them on the ground.
Now this is just his opinion, but he seemed to know Corvettes (better than I...) and I have heard similar statements from other people. But I have also heard the complete opposite in that headers can make a huge difference. I have seen a dynograph of zwede's 454, and he got something like 60 rwhp! Don't recall what other factors may have contributed to this.
What do the other guys with BB's and headers think? Please tell me what other mods your setup had at the time.
Does the story change if I add a better camshaft to the plot?
[Modified by Turbo-Jet, 8:56 PM 8/16/2001]
:cheers:
Pat Kunz
[Modified by Turbo-Jet, 8:56 PM 8/16/2001][/QUOTE]
That's a new one on me!? :confused: :bs :confused:
Norval
:cool:
The BBC manifolds are certainly some of the better designs compared to the standard GM log-type, but they're not up to performing like a header. Headers are almost always a great addition. Of course you open yourself up to potential customization on the exhaust, collector leaks, ground clearance problems, and steering/frame interference; but a good designed header won't have too many of these problems and will give you a decent performance gain.
As to perf improvement. Some improvement , certainly so on the track but on the street when closed up? I don't think so. Likely a slight improvement in gas consumption but given the BB what is going from 8 to 9 mpg or 10 to 11 worth as a trade against the annoyances? Zero to me.
For my money unless your racing on the track where every tenth counts forget it.... Kid Stuff.
Plug changes are no harder than stock manifolds. Starter comes off. Oil pan comes off. I use mid-price gaskets (mr gasket ultra seals) with silicone around the ports and they do not leak. It is important to retighten once after the gasket compresses, but after that I have not had to retighten at all.
The perf difference is very real, as can be seen on my webpage. The test on the webpage was done when the engine was stock except a mild cam (219/229 flat tappet), torker II and holley 750.
is there any way do get away from flatten pipes without major clearance issures? what vendors make a system like this?
thanks :cheers:
If you want more power than that you will neeed a high rise intake, L-88 hood, headers and headwork. Definitely not stock looking anymore.
Chuck
