Does a 700R4 need a cooler?
Old Mar 31, 2006 | 12:22 PM
johnyrundle's Avatar
johnyrundle
Default Does a 700R4 need a cooler?
Title says it all. I just put a 700R4 in from rossler and want to know if it needs a transmission cooler. I hear they have poor circulation and even that they dont send fluid around in overdrive?? Any tech info would be great, and how do I even tell the temp my tranny is?
Old Mar 31, 2006 | 12:31 PM
lars's Avatar
lars
Yes, it needs a cooler, but the in-radiator cooler is adequate for most stock applications. It does not need to run the fluid through the cooler when in OD since the converter is locked up in this configuration. With the converter locked up, there is no heat being generated from converter slippage. But in stop-n-go traffic, and when the converter is not locked, there will be as much heat generated as any other auto trans. The cooler you can keep it, the longer it will last.
Old Mar 31, 2006 | 03:13 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
Originally Posted by johnyrundle
.....how do I even tell the temp my tranny is?
i think the temperature sender unit goes into where the oil pressure "plug" is towards the front on the drivers side on the top half
Old Mar 31, 2006 | 03:51 PM
mrvette's Avatar
mrvette
Lars is right, but only to a point, the use of any 700r4 based tranny in any vechicle wether stock or not is problematic at BEST, the failure rate exceeds most any other tranny out there, it's THAT BAD....there is an inherent weakness of cooling in the 3/4 clutch pack, and has been attempted to be corrected about a dozen times from various aftermarket vendors...the list of possible clutch combos and drums and whatevers, plus drilling passages for superior cooliing/oil circulation seems to be not effective enough to cure the problems....meaning basic design is not worth a damn.....go to any site with parts available for the 700r4 and look at about 200 items or some such stupid high number....all that just to mod the unit to so called Hi Perf Specs.....forgetaboutit....
YES the tranny need the very largest cooler you can find, a freaking freezer/chiller to a tractor/trailer may well fill the bill, but maybe not....
GENE
Old Mar 31, 2006 | 04:04 PM
lars's Avatar
lars
I have 300,000 miles on an original 700R4 with no rebuild and 2 fluid/filter changes. No problem. Very reliable tranny in my C4.
Old Mar 31, 2006 | 07:56 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
GENE
I have a dump truck cooler for my th400.
Old Mar 31, 2006 | 08:05 PM
comp's Avatar
comp
Old Mar 31, 2006 | 08:44 PM
carl a's Avatar
carl a
i got 325,000 miles on my gmc safari ,,and the odometer broke 3 yrs ago !! so i must be a canadate for the guiness book of world records,,i dont know how many are on it now,,,w/ a 700 r-4 its a 1989.so.i think i got my moneys worth,,b t w its a 4.3 liter and i still never add any oil between 3,000 mile changes frt end was greased every other oil change all origional tie rods ball joints everything but the idler arms,,, there lifetime guarenteed,,so i dont care about them going out,,and the design blows...i bought a cooler for the 73.s 700r-4,,,but havent found a place i like it mounted,,think i may go w/ the ''heat sink''looking remote cooler ...you can mount it anywhere, so i have read..doesnt have to go in frt of the engine for air flo..if i get a third of those miles out of the vettes 700r4 ill be happy.. cant beat the 2200 rpms at 80 mph w/373 rear gears,,
Old Mar 31, 2006 | 08:49 PM
carl a's Avatar
carl a
Old Apr 1, 2006 | 08:04 AM
markdtn's Avatar
markdtn
My wife's Suburban is pushing 200K miles on a 4L60E which is the same guts as a 700R4. Had a fluid change at 100k, ready for another one. That's it, never a moments problem with it. Tow boats and cars on trailers regularly. They are not THAT BAD! I also have them in my 69 and my 83 truck. The original one in the 83 truck went 80k pulling trailers probably half that mileage before it ate the front pump-but that was good for the early ones. Just because some people can't find somebody to build it and properly set it up does not make it a bad transmission. Yes, the early ones had issues; get an 88 up for a core and you'll be fine. TV cable adjustment is critical on these. Don't put it in and think "i'll get to it later".
To answer the original question, yes you need a cooler like any automatic. In my opinion you do not need an extra auxillary cooler in a Corvette unless you are making serious power. For a cruiser car, the one in the radiator is enough.
Old Apr 1, 2006 | 10:08 AM
The Money Pit's Avatar
The Money Pit
I installed a 10"X15" cooler n front of my Griffen aluminum radiator (no tranny circuit) and ran a TCI guage with the sender in the pan. Never went over 170,even on 95 degree days pulling hills.
The 406 and I both agree the 700r4 wll not hold serious power,so a full manual th400 tranny is in the works.A cruiser should have no problem,as the innards of the 700r4 are the same basc rating as the th350 in stock form.
Old Apr 1, 2006 | 10:25 AM
1972warship's Avatar
1972warship
I can tell you in the South where I live it gets pretty hot, and my 700 use to get really hot. I could tell b/c the metal part of the shifter would about burn my hand. I installed a tranny cooler and the shifter just gets a little warm. I know not the most scientific way, but it is enough proof for me.
This was in stop and go driving.
Old Apr 1, 2006 | 01:28 PM
carl a's Avatar
carl a
anyone using one of those heat sink type coolers that dont have to be mounted in frt of the engine??? hows it working??
Old Apr 1, 2006 | 03:22 PM
71rdster's Avatar
71rdster
My Suburban has right at 110k miles, and I am on my 4th 4l60e. First two in warranty period. My local trans shop does not recommend 4l60E for performance or heavy duty apps. They do recommend 4l60 (700r4 or 2004r). There are greater differences between 4l60e and 700r4.
Old Apr 1, 2006 | 03:51 PM
carl a's Avatar
carl a
i thought the only difference was the 4 l 60 e was a computer controlled version of the 700 r-4?
Old Apr 1, 2006 | 05:03 PM
77TSi-meez's Avatar
77TSi-meez
To Does a 700R4 need a cooler?
