TA experts need opinion
Old Apr 2, 2006 | 04:11 PM
Warhead's Avatar
Warhead
Default TA experts need opinion
Brief recap, installing rebuilt TA from VanSteel. Passenger side no problems. Drivers side, as soon as I tighten caliper rotor refuses to turn by hand. I am thinking either bent caliper bracket or spindle not seated on bearing all the way. Whats your opinion
Passenger side bracket
Drivers side
from what I can see there is atleast 3/64 difference
Also noted the distance from E-brake pads to rotor, passenger side closer to pads than drivers side.
Plus 5 of these were holding on the rotor on the drivers side. Are these not thread die's??
Old Apr 2, 2006 | 04:51 PM
wnjlt1's Avatar
wnjlt1
it's going to be hard to determine what's wrong through pics. you may have to disassemble to get a better idea. did you purchase the arms complete with bearings and rotors? can you add some washers between the caliper and mount bracket to center the caliper just to see if the binding goes away? those do look like thread dies to me
*adding washers would bring caliper inwards...please disregard
Old Apr 2, 2006 | 05:01 PM
sperkins's Avatar
sperkins
I would guess the bearing is suspect. I would try to re-seat it. Keep in mind that there is supposed to be slight resistance on the pad. Does it not turn at all? Also, those do look like dies to me. Did the other side have them?
Good luck and keep us posted!
Old Apr 2, 2006 | 05:50 PM
Warhead's Avatar
Warhead
I purchased an assembled unit from Vansteel, did no assembly myself other that throw them on the car. It is the outside pad that is binding, piston is fully compressed when caliper is tight, washers will not work in this cast.
Old Apr 2, 2006 | 05:58 PM
masterspydog's Avatar
masterspydog
the items in pic 3 are thread dies - i cannt believe someone could/ would send those out on a product
Old Apr 2, 2006 | 06:01 PM
jdmick's Avatar
jdmick
WTF
Old Apr 2, 2006 | 07:42 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
If you would like, I can have UPS pick it up and we can take a look at it for you. Just call me Monday morning and I'll send a call tag for them.
Those nuts are dies. We put dies on all threads to make sure they are clean. My guy that builds them accidentally left them on.
Old Apr 2, 2006 | 08:00 PM
Warhead's Avatar
Warhead
Thanks for ringing in, I will call tomorrow.
To TA experts need opinion
