79' L82 Smog pump
Old Apr 2, 2006 | 07:05 PM
SULLY_PA's Avatar
SULLY_PA
Default 79' L82 Smog pump
I'm in the process of taking some parts out of the engine compartment to repaint ...valve covers, intake, brackets, etc ....and took the smog pump off ....I'd really like to keep it out and plug the stuff it was hooked too....will it effect anything if I do and what other then plugging the holes should I look for ...thanks
Old Apr 2, 2006 | 08:00 PM
AlCherry's Avatar
AlCherry
If you can do it legally, go all the way, pump, egr, canister vacuum lines, ALL OF IT! You will be able to see the motor, get to your plugs. My EGR was bad, causing my motor to smoke. Pulled it off and the smoke cleared out.
Old Apr 2, 2006 | 08:41 PM
JoeRags's Avatar
JoeRags
check your local laws. if you can, scrap all of it!!! free up some HP while your at it.
Old Apr 2, 2006 | 08:56 PM
AlCherry's Avatar
AlCherry
The canister under your left fender, not your vacuum canister. Screw the greenhouse gasses!
Old Apr 2, 2006 | 08:59 PM
SULLY_PA's Avatar
SULLY_PA
thanks guys ....thats exactly what I'll do
To 79' L82 Smog pump
