I'm looking to replace my existing 454 motor mounts with new poly. I've looked on Summit and other suppliers but not sure which ones I need. The ones on the car are totally gone, btw its a 68 vert with a late 70's 454 block. The site mention clam shells, can anyone point me in the right direction? What specific type of motor mounts am I looking for and whats the best place to find them? Thanks
Also, the differential mount bushings that sits right below the drive-shaft U-joint, is that called the "Differential Pinion Mount Grommet"? I'm looking to replace that as well along with the trans mount. Where can I find that differential bushing? (not the crossmemeber bushings)
I purchased mine through Sumit and were made by Energy Suspension. They sare said to be as strong and solids but off a smoother ride, no complints from me as of yet.
