Brake light switch/ "proportioning valve"
Old Apr 4, 2006 | 12:00 AM
70 LS1's Avatar
70 LS1
Default Brake light switch/ "proportioning valve"
I know that at least on the early C3's the proportioning valve is not really a valve, but a differential switch to light up the dash light if you loose pressure one side.
Now for my question. If you loose pressure on one side, lets say rear, will the piston shift over and stop all fluid flow, or will it just move over and still allow fluid to pass to the rear circuit.
The reason I am asking is I am installing dual master cylinders of different sizes on my car and would like to keep the light switch. I guess its really not that important, but would make the plumbing a little easier.
Old Apr 4, 2006 | 01:48 AM
Z-man's Avatar
Z-man
As I remember from real life , it allows the remaining two brakes to function correctly. You can limp home if this happens (or in my case, drive for approximately 6 months while saving for new calipers.) Black electricians tape shields the driver from the glare of the red brake light...
(I'll verify this with my assembly manual and get back...)
Old Apr 4, 2006 | 03:24 AM
tfi racing's Avatar
tfi racing
It is actually a combination valve.It makes the brake warning light operate in case of a hydraulic failure on one side of the system and limits the pressure to the rear brakes during normal operation.If you are putting in dual masters you probably will want to put in an adjustable proportioning valve in the rear brake line.If you are advanced enough to need dual masters,you shouldn't need an idiot light to tell you that there is something wrong with your brakes!
Old Apr 4, 2006 | 08:34 AM
Duke94's Avatar
Duke94
"Now for my question. If you loose pressure on one side, lets say rear, will the piston shift over and stop all fluid flow, or will it just move over and still allow fluid to pass to the rear circuit."
If you loose pressure, the piston will shift over but will still allow fluid to flow even on the failed side. If you are working on your 70 LT1, it only has a differential valve (NO rear proportioning). As others have suggested, you may want to install an adjustible prop valve in the rears.
Old Apr 4, 2006 | 09:58 AM
70 LS1's Avatar
70 LS1
With the two masters there is a balance bar that allows the driver to adjust the front to rear bias. No need for a proportioning valve.
I mostly wanted to keep the block for ease of plumbing. I already have all new brake lines and would like to replace as few of those as possible.
Old Apr 4, 2006 | 10:16 AM
70 LS1's Avatar
70 LS1
Thanks, thats what I was looking for. I am going to be using two different sized masters 3/4" front and 7/8" rear and wanted to make sure that the switch wouldn't stop fluid flow to the rear because the pressure is lower.
To Brake light switch/ "proportioning valve"
