C3 WITH 454`S chime in
Old 04-04-2006, 08:30 AM
Kryptonite
Kryptonite's Avatar
Default C3 members with 454`S chime in
Guys some feed back on what camshaft you guys have installed and what results I plan to stay with stock intake and exhaust manifolds and the stock 1800 converter in 400 trans. My cam is shot and looking to use a kit and replace rockers and pushrods also.
Old 04-04-2006, 09:24 AM
zwede
zwede's Avatar
The stock intake and exhaust is very restrictive so I'd stay with a cam with no more than 220 dgr duration @050. There are many grinders out there with cams like this. Comp, Crane, Isky, Lunati etc etc. If you want some lope at idle you can order it with a tight lobe separation. About 108 should lope some. A 112 LSA will idle smooth. Your choice.
Old 04-04-2006, 09:54 AM
Kryptonite
Kryptonite's Avatar
Default valve springs
zwede Would my stock valvesprings work with that cam
Old 04-04-2006, 10:03 AM
68 NJConv 454
68 NJConv 454's Avatar
Sounds like Zwede knows his stuff. Unfortunately I don't know that much about all those engine numbers stuff. Need to learn a bit. Anyone running a 4spd with their 454? My 454 is a late 70's block but with the original 4spd muncie. The clutch fork hits the driver floor right beneath the gas pedal so there's a huge hole. I haven't driven the car since I only purchased it in late dec. Any of you C3's with a 454 have this issue or know how to solve it? Don't mean to jack your thread but I don't see many threads geared towards the 454 c3. I will also be looking to modify my engine next year so I'm in the research stage. Good luck.
Old 04-04-2006, 10:40 AM
73, Dark Blue 454
73, Dark Blue 454's Avatar
Zwede is right on,..something in the 220-222 range would be great. You might look at Comp's High Energy line,..very torquey stuff.
Good luck!
Old 04-04-2006, 10:49 AM
BBNJKen
BBNJKen's Avatar
I just finished replacing the cam, rockers, heads, intake and carb on my 72 454, haven't got too much seat of the pants dyno time on the road yet. The object was to acheive a low-mid range torque monster, with neck snapping throttle response off idle.
I probably went way too conserveative on the cam, I don't recall off hand the P/N, but its a Crane hydralic, with .499 lift on both the I & E. Very smooth idle, something like 24" of Hg manifold vac. @ idle in nutrael. The P.O. had put in an early Crane Fireball cam with about the same lift, but a lot more overlap, resulting in **** poor vac @ idle, which contributed to crummy PB function.
I added Edelbrock's Performer alum. heads and Comp Cams roller rockers, a dual plane manifold, and a 650 CFM Vac secondary Holley. I am in the process of installing a L-88 style hood to cap it off. Once I get a little more road time, I'll post my impressions.
Cheers
BB NJ Ken
Old 04-04-2006, 11:26 AM
kdf1986
kdf1986's Avatar
check out this forum thread posted by zwede.
http://www.corvetteforum.net/c3/zwed...ain/mods_2.htm
It goes through some of the modifcations he made to his 71 454.
kdf
Old 04-05-2006, 10:36 PM
dn69427
dn69427's Avatar
Default 69acint
Hope this helps, I have a 69 427 30 over, that I put in a comp cam 268H. Don't know the specifics, brother in law helped - "drag racer in San Diego" anyway he told me its the biggest cam I could put in with an automatic, and I was going for the low end range, that was in 98. Awesome throttle response, very happy.
Old 04-06-2006, 06:05 AM
jerrylee
jerrylee's Avatar
that's the same one i have in my 454 rebuild....i am just waiting 4 the engine to be installed next week......hows the performance with the 268.........i know a lot of guys were giving her the thumbs down so i called comp n the tech said that i could of went one bigger but it would work just fine n give me a lot of low end power...so is this true n also hows the sound...thanx....
Old 04-06-2006, 10:31 AM
68 NJConv 454
I'm not sure of the specs of my engine. All i know is its a late 70's PASS 454 in 68 vette. I pulled the clutch assembly and flywheel last night and found "HI PERF" stamped on the rear of the engine. Any of you guys have this marking on your 454 blocks? trying to figure out if this is a vette engine and what it produced stock. Haven't opened her up yet to see whats inside. Any thoughts?
Old 04-06-2006, 09:57 PM
jerrylee
jerrylee's Avatar
Default 454...
hello jersey..my block says hi perf also...it's not a vet engine.....all i know is that it's a mark 1V block used between 78'- 87'..do u have a block I.D.#......
Old 04-07-2006, 06:02 AM
2th farmer
2th farmer's Avatar
CI 6-8-9 Veteran
I used Comp cams 270 hydraulic roller. (218-224 @ 50 with 510 lift) Good street cam probably could have gone to the 280. Consider replacing the intake and heads with aluminum. A lot more $$ but you'll "feel" the difference both by weight and seat of your pants. These BB's need to breathe!
Old 04-07-2006, 06:51 AM
Kryptonite
Kryptonite's Avatar
Default intake
I would just dont want to change my hood, great looking engine.
Old 04-07-2006, 10:24 AM
68 NJConv 454
JerryLee,
Have most of my info at home but I have written down
Block # 361959
VIN: C9Z209270
Intake is an aluminium 66-68 396ci L78 model # 3885069
U know of a source of ID #'s for GM? I've been pulling everything off my vette to rebuild and I'd like to see what the #'s on my engine, trans, and differential mean.
Old 04-07-2006, 11:59 AM
zwede
zwede's Avatar
From www.mortec.com:
361959.....454.......73-90...2 or 4 bolt
Old 04-08-2006, 08:36 AM
jerrylee
jerrylee's Avatar
Default 454...
zwede beat me 2 the punch...mortec is a cool site with lots of info...there is also a sect regarding the hi perf stamp on the engines....
To C3 WITH 454`S chime in
Quick Reply: C3 WITH 454`S chime in
