Help! two cylinders leaking oil causing vibration
Old Aug 17, 2001 | 06:36 PM
chrled's Avatar
chrled
Default Help! two cylinders leaking oil causing vibration
My autoshop gave me two ways to solve my two bad cylinders.
1. Change valve sealers 300$
2. Change the engine to a delco remanufatured 350 total USD 2500
I have a L48 Corvette 79
Please advise ASAP!
Thanks.
Christian
Old Aug 17, 2001 | 06:44 PM
KenSny's Avatar
KenSny
Default Re: Help! two cylinders leaking oil causing vibration (chrled)
Since the valve seals are in the heads, here's a third way - change the heads - less cost than a new engine. Since when is it easier to change the engine than the valve seals. They must know something else is wrong somewhere.....
Old Aug 17, 2001 | 06:55 PM
chrled's Avatar
chrled
Default Re: Help! two cylinders leaking oil causing vibration (KenSny)
Thanks!
Chris.
To Help! two cylinders leaking oil causing vibration
