Hydraulic Clutch conversions
Old Apr 5, 2006 | 06:05 PM
Golden's Avatar
Golden
Default Hydraulic Clutch conversions
Hi, I have a '71 350 stick with a Hayes clutch in it but have a weak knee.
Is there a hydraulic conversion available for this model that would make the clutch lighter? Or is there any other way to reduce the pedal pressure.
Many thanks all
Old Apr 5, 2006 | 08:07 PM
norvalwilhelm's Avatar
norvalwilhelm
Many thanks all
Golden I have posted on this conversion many many time and even over the last winter there have been numerous posts on this.
Old Apr 6, 2006 | 07:52 AM
BerniesVette's Avatar
BerniesVette
The hydraulic clutch is great. Very light pressure to use. We bought a master cylinder and slave cylinder for a 1985 one ton chevy truck. The master cylinder fits perfectly; the only thing you need to do is shorten the rod to the correct length. Make a bracket for the slave and you are good to go. You can buy a resevior from coleman racing or go to a junk yard and get one from a camaro with hyd clutch.
Bernie
Old Apr 6, 2006 | 07:55 AM
Golden's Avatar
Golden
Cheers guys
Old Apr 7, 2006 | 12:49 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Norval's posts should be available using "advanced search" and checking the "archves" box.
To Hydraulic Clutch conversions
