#4 body mount
Old Apr 7, 2006 | 01:40 AM
gator79's Avatar
gator79
Default #4 body mount
I had to cut the bolt off on my #4 body mounts and now I need to put the body back on the frame. the bracket that holds the nut is in good shape, I just need to get the nut out. can I cut an access hole from the rear and get it out then just glass it back up? also I remember someone putting the bolt thru the bracket and the nut on the bottom.
Old Apr 7, 2006 | 07:50 AM
GUSTO14's Avatar
GUSTO14
gator79...
The bracket you are referring to is the "nut cage". It's what traps the nut and holds it in place so it doesn't turn while you screw the body bolts in. If you had to cut the original bolt and there is any of it sticking above or below the "nut" you are going to have to remove the "nut cage" (at least damage it severely) to pull out the remnants of the old nut/bolt and replace it with a new nut.
The "nut cage" is riveted to the body/lower mount and comes out pretty easily. It is not the easiest job to rivet it back in and it's much easier if you have an assistant to help. Some folks have just removed the old nut and cage and put a nut and washers on the body bolt. It's not easy to get access to however, especially on a convertible, but it is doable…
Don't forget to use a generous helping of anti-seize on the bolts when you reinstall them…
Good luck… GUSTO
Old Apr 7, 2006 | 10:19 AM
68 NJConv 454's Avatar
68 NJConv 454
humm tuff one. I just removed mine, Usually the nutcage breaks well before the bolt has to be cut. If you gut the head off the bolt on the bottom then I'm assuming either you have one steroid pumped nut cage or that bolt is rusted throughout. Make sure the bolt is not binded/rusted to the lower reinfocement (upsidedown cap that sits b/w the body and the framemount). I would then pop the rivets off the nutcage and punch the bolt up thru the body still attached to the nut and nut cage. Don't even both trying to drill it out. Then just buy a new nut, nut cage and bolt from a corvette supplier. I should be getting mine today along with the lower and upper reinforcement since mine rusted out and reinstall. Use good rivets and antiseeze for long gevity. If its a coupe you might get away with skipping the nutcage and putting the bolt on top and nut on bottom but if its a convertible where access is an issue it make it easier to do it the factory way. And yes mine is a 68 vert which makes it a PIA! Good luck.
Old Apr 7, 2006 | 05:20 PM
Victor's Avatar
Victor
I haven't gotten to the reassembly part of my '79 project yet, but I had the same issue with one of my #4 body mounts. Placing a large washer in place of the nut cage is exactly what I was planning on doing.
Those body mount bolts are a bitch to cut. I don't remember how many blades I went through on my jab-saw cutting just one bolt...
Old Apr 7, 2006 | 10:39 PM
77 vette's Avatar
77 vette
When I tried to remove my #4 passinger side bolt it sheared the nutplate off, the 2 rivets attaching it shreaded the fiberglass inner housing, I cut and removed the bolt and nutplate. On the drivers side I shaved the bucktails off the rivets that attach the plate to the inner housing, I cut and removed the bolt and nutplate, I then attached 2 new nut plates to two .125" thick aluminum rounded square plates, I first drilled a through hole in them for the new bolt pin to stick out. I then glassed them in and bolted it back up
To #4 body mount
