Can this be fixed
Old Apr 8, 2006 | 05:25 PM
Silver00V6Camaro's Avatar
Silver00V6Camaro
Default Can this be fixed
looks like my lower a arm weld broke.. Has any one every had this happen to them.
Old Apr 8, 2006 | 05:29 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Yep you should be able to fix it.
Old Apr 8, 2006 | 05:30 PM
Silver00V6Camaro
i hope this damn car is driving me up the wall and takin all of my money
Old Apr 8, 2006 | 05:33 PM
Twin_Turbo's Avatar
Twin_Turbo
common problem, relativly easy fix. That's the reason why it's a good idea to weld the channels completely, weld the mounts completely, use gussets and a spreader bar.
Old Apr 8, 2006 | 05:35 PM
Silver00V6Camaro
Originally Posted by Twin_Turbo
common problem, relativly easy fix. That's the reason why it's a good idea to weld the channels completely, weld the moutns completely, use gussets and a spreader bar.
What is the speader bar and a gusset
Old Apr 8, 2006 | 05:58 PM
stingraymaniac's Avatar
stingraymaniac
that has happened to mine.its welded up on the passenger side,former owner did it,shouldnt be a problem fixing that
Old Apr 8, 2006 | 06:01 PM
Silver00V6Camaro
how did you all go about fixing it. Did you just put a floor jack under the lower a arm and get back into place?
Old Apr 8, 2006 | 06:23 PM
NHvette's Avatar
NHvette
Gussets are welded in supports.
Spreader bar is after market equipment that
mounts between the two shock towers to reduce frame
flex in the front. See http://www.vbandp.com for spreader bar
Push it up with a floor jack might work if the bracket lays flat again.
At least fully weld up the sides ... gussets are optional.
The other ones I've seen were due to rust at the front two bolts.
like this: http://NHvette.com/ftp/in/front_gusset_09.jpg
Change the "09" in the above link to "01" through "08" to see my gusset installs.
I did mine before any problems during the body-off.
Good Luck
Excuse my crappy welds. That's a jacking plate that I made to cover the dented crossmember.
Old Apr 8, 2006 | 06:29 PM
Silver00V6Camaro
Thats looks good. thanks for the info another thing i am going to have the car towed to a local welding shop that has done a bunch of welding for me before they welded the rear end in my dads street rod when i broke lose. My next question is what all do i have to remove to get this welded.?
Old Apr 9, 2006 | 11:54 AM
Silver00V6Camaro
ttt
Old Apr 9, 2006 | 12:02 PM
Twin_Turbo's Avatar
Twin_Turbo
the suspension corner needs to be removed, apart from the upper control arm. Then clean the entire area as thorough as you can, clean clean and wipe w/ alcohol. You want it so clean you can lick the bare metal Then with a jack push everything back in place and weld it completely through.
Old Apr 9, 2006 | 12:17 PM
comp's Avatar
comp
Old Apr 10, 2006 | 08:07 PM
Silver00V6Camaro
This is gonna sound stupid but is it possible to put large toggle bolts in the channel into the crossmember to get it in the right spot so i can drive it to the welding shop.
Old Apr 10, 2006 | 08:14 PM
shafrs3's Avatar
shafrs3
Not a good idea.
Old Apr 10, 2006 | 08:55 PM
Silver00V6Camaro
Originally Posted by shafrs3
Not a good idea.
Well what is a good way to fix it i know it needs welding but i have to get it to a welding shop, and if i have to take the driver side suspension off then I wont have the wheel on it. So basiclly put i need to know can this be done with the suspension in place or am i gona have to remove it.
Old Apr 10, 2006 | 09:05 PM
Twin_Turbo's Avatar
Twin_Turbo
read above, susp. needs to be removed to fix it properlu. Arrange a flatbed or a trailer.
Old Apr 10, 2006 | 09:33 PM
Silver00V6Camaro
ok i guess the next question is how hard is it to remove the suspension.
To Can this be fixed
Old Apr 10, 2006 | 09:49 PM
rihwoods's Avatar
rihwoods
At least all day....
Old Apr 10, 2006 | 09:54 PM
windsoreight's Avatar
windsoreight
I noticed during my engine replacment that the driverside rear control arm mount has a cracked weld. I cleaned it up and re-welded it. Yours looks fixable with a little work.
Old Apr 12, 2006 | 06:29 PM
Silver00V6Camaro
Once i get the rotor assy. off the car can i just remove the spring and shock or do the a arms have to come off?
